Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
Sony Vaio Tap 11 Internal Speakers Replacement
Qué necesitas
  1. Sony Vaio Tap 11 Internal Speakers Replacement, Screen Assembly: paso 1, imagen 1 de 1
    • Begin by opening the HDMI/USB port cover on the left edge.
    • Remove the three #000 headed, 3 mm long screws located underneath the port cover.
  2. Sony Vaio Tap 11 Internal Speakers Replacement: paso 2, imagen 1 de 1
    • Locate and open the Micro SD slot on the top side of the device.
    • Remove the two screws located beneath the cover.
  3. Sony Vaio Tap 11 Internal Speakers Replacement: paso 3, imagen 1 de 2 Sony Vaio Tap 11 Internal Speakers Replacement: paso 3, imagen 2 de 2
    • Attach the suction cup to the top right area of the screen.
    • Pull to separate the screen from the rest of the device.
    • Be aware of the front camera cable that is still connected to the rest of the device.
    • Detach the display ribbon cable.
  4. Sony Vaio Tap 11 Internal Speakers Replacement, Battery: paso 4, imagen 1 de 1
    • Disconnect the battery from the motherboard by pulling out the cable below the fan.
  5. Sony Vaio Tap 11 Internal Speakers Replacement: paso 5, imagen 1 de 1
    • Remove the seven 3 mm Phillips #000 screws that hold the battery in place.
    • Carefully remove the battery from the back assembly.
  6. Sony Vaio Tap 11 Internal Speakers Replacement, Motherboard: paso 6, imagen 1 de 1
    • Remove the nine 3 mm Phillips #000 screws holding in the motherboard.
  7. Sony Vaio Tap 11 Internal Speakers Replacement: paso 7, imagen 1 de 1
    • Remove the black plastic dust shield by gently pulling it up.
    • You'll want to keep the sticky side up so you can replace it when reassembling. This part also functions as a shield for the sensitive camera component!
  8. Sony Vaio Tap 11 Internal Speakers Replacement: paso 8, imagen 1 de 3 Sony Vaio Tap 11 Internal Speakers Replacement: paso 8, imagen 2 de 3 Sony Vaio Tap 11 Internal Speakers Replacement: paso 8, imagen 3 de 3
    • Before removing the motherboard, there are a few cables to disconnect.
    • Disconnect the cable connected to the top of the display.
    • Disconnect the power jack connector on the left side of the screen.
    • Disconnect the daughterboard connector located above and to the right of the WiFi chip slot.
  9. Sony Vaio Tap 11 Internal Speakers Replacement: paso 9, imagen 1 de 2 Sony Vaio Tap 11 Internal Speakers Replacement: paso 9, imagen 2 de 2
    • Gently pull the motherboard out by pulling from the right side of the board and flip it so that the motherboard now sits where the battery was and the underside is now visible.
    • There is still one cable to remove!
    • Remove the speaker connector located next to the SSD slot.
    • You may now remove the motherboard from the device.
  10. Sony Vaio Tap 11 Internal Speakers Replacement, Internal Speakers: paso 10, imagen 1 de 1
    • Remove the four 3 mm Phillips #000 screws from the upper and lower ends of each speaker module.
  11. Sony Vaio Tap 11 Internal Speakers Replacement: paso 11, imagen 1 de 2 Sony Vaio Tap 11 Internal Speakers Replacement: paso 11, imagen 2 de 2
    • Once the speakers are loose, follow the wires and remove any tape holding them to the assembly.
    • The speaker connector should have been disconnected in the motherboard prerequisite.
    • The speaker wiring and assembly should now be completely free to remove from the tablet assembly.
Conclusión
Una persona más ha completado esta guía.
Kevin
Miembro Desde 09/16/15
276 Reputación
2 Guías creadas
Equipo
IUPUI, Team 1-2, Harley Fall 2015 Miembro de IUPUI, Team 1-2, Harley Fall 2015
IUPUI-HARLEY-F15S1G2
Miembros de 4
20 Guías creadas
1Guía Comentario
If the speakers are burned and not working what is the type/model/part number of them which I must know to buy new ones?
harkarag - Contestar Compartir
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 9
Ultimos 30 días: 45
Todo El Tiempo: 1,601
