Introducción
Fixing the audio jack on a tablet is important for anyone who relies on wired headphones or external audio devices for everyday use. Whether it’s listening to music, making hands-free calls, or connecting to speakers, a functional audio jack ensures clear sound quality and a consistent connection without the need for Bluetooth or wireless alternatives.
Repairing the jack can save money compared to buying a new phone or switching to expensive wireless accessories. Plus, it helps extend the life of your device and reduce electronic waste, making it a practical and environmentally conscious choice.
This guide will provide the steps necessary to replace the audio jack in your Sony Vaio Tap 11 tablet.
Before you begin this repair, power off your laptop and unplug it from the power adaptor.
Qué necesitas
Begin by opening the HDMI/USB port cover on the left edge.
Remove the three #000 headed, 3 mm long screws located underneath the port cover.
With the screws removed, use a plastic opening tool to lightly pry the board up over a plastic positioning peg.
Insert the tip of a spudger where the upper screw was located and push the board inward while prying up with the plastic opening tool.
Lightly pry with the opening tool, enough for the board to lift off the positioning peg and then push inward with the spudger. The board should begin to separate from the corner.
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
3 personas más completaron esta guía.
