Saltar al contenido principal
Sony Vaio SVT151A11L Multimedia Card Reader Replacement
Qué necesitas
  1. Sony Vaio SVT151A11L Multimedia Card Reader Replacement, Battery: paso 1, imagen 1 de 2 Sony Vaio SVT151A11L Multimedia Card Reader Replacement, Battery: paso 1, imagen 2 de 2
    • Flip the laptop over so that the battery on the underside of the device is revealed.
    • Unscrew the two 11mm slotted silver screws that can be found at the top of the battery.
  2. Sony Vaio SVT151A11L Multimedia Card Reader Replacement: paso 2, imagen 1 de 3 Sony Vaio SVT151A11L Multimedia Card Reader Replacement: paso 2, imagen 2 de 3 Sony Vaio SVT151A11L Multimedia Card Reader Replacement: paso 2, imagen 3 de 3
    • Wedge the plastic opening tool between the back panel and the battery on the top left side of the device.
    • Push down on the plastic opening tool until the battery lifts from the back of the laptop.
    • Grab the battery and remove it from the device.
  3. Sony Vaio SVT151A11L Multimedia Card Reader Replacement, Back Panel: paso 3, imagen 1 de 3 Sony Vaio SVT151A11L Multimedia Card Reader Replacement, Back Panel: paso 3, imagen 2 de 3 Sony Vaio SVT151A11L Multimedia Card Reader Replacement, Back Panel: paso 3, imagen 3 de 3
    • Unscrew the three 4mm screws using a JIS #0 screwdriver.
    • Unscrew the eight 7 mm screws using a JIS #0 screwdriver.
    • Grab and lift the edge of the panel to pull it free from the rest of the computer.
  4. Sony Vaio SVT151A11L Multimedia Card Reader Replacement: paso 4, imagen 1 de 3 Sony Vaio SVT151A11L Multimedia Card Reader Replacement: paso 4, imagen 2 de 3 Sony Vaio SVT151A11L Multimedia Card Reader Replacement: paso 4, imagen 3 de 3
    • Grab the disk drive located at the edge of the computer and pull it it out.
    • Unscrew the three 7 mm screws with a JIS #0 screwdriver.
  5. Sony Vaio SVT151A11L Multimedia Card Reader Replacement, Multimedia Card: paso 5, imagen 1 de 1
    • Get unobstructed access to the multimedia card.
  6. Sony Vaio SVT151A11L Multimedia Card Reader Replacement: paso 6, imagen 1 de 2 Sony Vaio SVT151A11L Multimedia Card Reader Replacement: paso 6, imagen 2 de 2
    • Unscrew the two 2mm screws from the board using JIS #0 screwdriver.
  7. Sony Vaio SVT151A11L Multimedia Card Reader Replacement: paso 7, imagen 1 de 2 Sony Vaio SVT151A11L Multimedia Card Reader Replacement: paso 7, imagen 2 de 2
    • Lift up multimedia card.
    • Pull out ribbon cable from connected board.
  8. Sony Vaio SVT151A11L Multimedia Card Reader Replacement, Multimedia Card Reader: paso 8, imagen 1 de 1
    • Get unobstructed access to the multimedia card reader.
  9. Sony Vaio SVT151A11L Multimedia Card Reader Replacement: paso 9, imagen 1 de 2 Sony Vaio SVT151A11L Multimedia Card Reader Replacement: paso 9, imagen 2 de 2
    • Unscrew three 2mm screws using JIS #0 screwdriver.
  10. Sony Vaio SVT151A11L Multimedia Card Reader Replacement: paso 10, imagen 1 de 2 Sony Vaio SVT151A11L Multimedia Card Reader Replacement: paso 10, imagen 2 de 2
    • Gently lift up multimedia card reader.
    • Pull out ribbon cable from the board.
Conclusión
Equipo
UMass Dartmouth, Team S4-G6, Julie Fall 2017 Miembro de UMass Dartmouth, Team S4-G6, Julie Fall 2017
UMASSD-JULIE-F17S4G6
2 Miembros
12 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 8
Todo El Tiempo: 441
