Saltar al contenido principal
Sony Vaio SVT151A11L Battery Replacement
Qué necesitas
  1. Sony Vaio SVT151A11L Battery Replacement, Battery: paso 1, imagen 1 de 2 Sony Vaio SVT151A11L Battery Replacement, Battery: paso 1, imagen 2 de 2
    • Flip the laptop over so that the battery on the underside of the device is revealed.
    • Unscrew the two 11mm slotted silver screws that can be found at the top of the battery.
  2. Sony Vaio SVT151A11L Battery Replacement: paso 2, imagen 1 de 3 Sony Vaio SVT151A11L Battery Replacement: paso 2, imagen 2 de 3 Sony Vaio SVT151A11L Battery Replacement: paso 2, imagen 3 de 3
    • Wedge the plastic opening tool between the back panel and the battery on the top left side of the device.
    • Push down on the plastic opening tool until the battery lifts from the back of the laptop.
    • Grab the battery and remove it from the device.
Conclusión
3 personas más completaron esta guía.
Nathan McGarvey
Miembro Desde 10/20/17
481 Reputación
4 Guías creadas
Equipo
UMass Dartmouth, Team S4-G6, Julie Fall 2017 Miembro de UMass Dartmouth, Team S4-G6, Julie Fall 2017
UMASSD-JULIE-F17S4G6
2 Miembros
12 Guías creadas
4 comentarios
Just got the new Sony Vaio SVT151A11L Battery VGP-BPS33 Li-ion, 11.4V, 3760mAh, 43W,Silver , looks in good condition and similar as original. fix it in laptop and works well up to now. one more thing, it costs less than my thought.
julie - Contestar
what size screws and thread type are used for battery mount. i have lost mine
John Sears - Contestar
My computer battery is not contacted what i can do for this problem
Matiullah - Contestar
SVT151A11L
SVT15112CXS
Laptop computer
Battery not connected
What i can do
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 4
Ultimos 7 días: 14
Ultimos 30 días: 36
Todo El Tiempo: 3,367
