Saltar al contenido principal
Sony Vaio SVF15N17CXB Hard Drive Replacement
Qué necesitas
  1. Sony Vaio SVF15N17CXB Hard Drive Replacement, Back Panel: paso 1, imagen 1 de 1
    • Unscrew the eleven 6 mm screws from the back panel on the bottom of laptop with the Phillips #0 screwdriver.
    • Unscrew the one 4 mm screw from the back panel on the bottom of laptop with the Phillips #0 screwdriver.
    • 6 mm screws marked in red, 4 mm marked in orange
  2. Sony Vaio SVF15N17CXB Hard Drive Replacement: paso 2, imagen 1 de 2 Sony Vaio SVF15N17CXB Hard Drive Replacement: paso 2, imagen 2 de 2
    • Using a plastic opening tool, pull the optical drive out of the computer by the seam.
    • In reassembly, slide the optical drive back in after reapplying cover.
  3. Sony Vaio SVF15N17CXB Hard Drive Replacement: paso 3, imagen 1 de 1
    • Run the opening tool along the bottom cover seam.
  4. Sony Vaio SVF15N17CXB Hard Drive Replacement: paso 4, imagen 1 de 1
    • Lift the clip marked in red in order to release the back cover.
    • Lift the back cover.
  5. Sony Vaio SVF15N17CXB Hard Drive Replacement, Hard Drive: paso 5, imagen 1 de 1
    • Unscrew the three 4mm screws with the Phillips #0 screwdriver located on the outer edge of the hard drive.
  6. Sony Vaio SVF15N17CXB Hard Drive Replacement: paso 6, imagen 1 de 1
    • Lift hard drive up from it groundings.
    • Slide hard drive to the left in order to remove it.
Conclusión
Una persona más ha completado esta guía.
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 4
Ultimos 30 días: 11
Todo El Tiempo: 1,128
