Saltar al contenido principal
  1. Unscrew the eleven 6 mm screws from the back panel on the bottom of laptop with the Phillips #0 screwdriver.
    • Unscrew the eleven 6 mm screws from the back panel on the bottom of laptop with the Phillips #0 screwdriver.
    • Unscrew the one 4 mm screw from the back panel on the bottom of laptop with the Phillips #0 screwdriver.
    • 6 mm screws marked in red, 4 mm marked in orange
  2. Using a plastic opening tool, pull the optical drive out of the computer by the seam. In reassembly, slide the optical drive back in after reapplying cover.
    • Using a plastic opening tool, pull the optical drive out of the computer by the seam.
    • In reassembly, slide the optical drive back in after reapplying cover.
  3. Kits de Reparación de Batería de MacBook Air
    A partir de $69.99
    Buy Now
    A partir de $69.99
    Buy Now
  4. Run the opening tool along the bottom cover seam.
    • Run the opening tool along the bottom cover seam.
  5. Lift the clip marked in red in order to release the back cover.
    • Lift the clip marked in red in order to release the back cover.
    • Lift the back cover.
  6. Unscrew the three 4mm screws with the Phillips #0 screwdriver located on the outer edge of the hard drive.
    • Unscrew the three 4mm screws with the Phillips #0 screwdriver located on the outer edge of the hard drive.
  7. Lift hard drive up from it groundings.
    • Lift hard drive up from it groundings.
    • Slide hard drive to the left in order to remove it.
Conclusión
Quinn Walter
Miembro Desde 04/10/18
293 Reputación
2 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 1
Últimos 30 Días: 11
Todo El Tiempo: 97
