Saltar al contenido principal
Sony Vaio SVF15A16CXB Battery Replacement
Qué necesitas
  1. Sony Vaio SVF15A16CXB Battery Replacement, Back Panel: paso 1, imagen 1 de 1
    • Unscrew the eleven 6 mm screws from the back panel on the bottom of laptop with the Phillips #0 screwdriver.
    • Unscrew the one 4 mm screw from the back panel on the bottom of laptop with the Phillips #0 screwdriver.
    • 6 mm screws marked in red, 4 mm marked in orange
  2. Sony Vaio SVF15A16CXB Battery Replacement: paso 2, imagen 1 de 2 Sony Vaio SVF15A16CXB Battery Replacement: paso 2, imagen 2 de 2
    • Using a plastic opening tool, pull the optical drive out of the computer by the seam.
    • In reassembly, slide the optical drive back in after reapplying cover.
  3. Sony Vaio SVF15A16CXB Battery Replacement: paso 3, imagen 1 de 1
    • Run the opening tool along the bottom cover seam.
  4. Sony Vaio SVF15A16CXB Battery Replacement: paso 4, imagen 1 de 1
    • Lift the clip marked in red in order to release the back cover.
    • Lift the back cover.
  5. Sony Vaio SVF15A16CXB Battery Replacement, Battery: paso 5, imagen 1 de 1
    • Unscrew the four 6mm screws with the Phillips #0 screwdriver.
  6. Sony Vaio SVF15A16CXB Battery Replacement: paso 6, imagen 1 de 1
    • Lift the battery and remove it from the laptop.
Conclusión
Una persona más ha completado esta guía.
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 5
Ultimos 30 días: 24
Todo El Tiempo: 2,734
