Saltar al contenido principal
Sony Vaio SVE171C11L Motherboard Replacement
Qué necesitas
  1. Sony Vaio SVE171C11L Motherboard Replacement, Motherboard: paso 1, imagen 1 de 2 Sony Vaio SVE171C11L Motherboard Replacement, Motherboard: paso 1, imagen 2 de 2
    • Turn the laptop facedown.
    • Locate the battery compartment at the top of the laptop base. You will see two tabs on it.
    • Push the two tabs up to release the battery. Set it aside.
  2. Sony Vaio SVE171C11L Motherboard Replacement: paso 2, imagen 1 de 2 Sony Vaio SVE171C11L Motherboard Replacement: paso 2, imagen 2 de 2
    • Rotate the laptop so the empty battery compartment is now at the bottom.
    • Remove the two screws that secure the hard drive cover using a T5 Torx screwdriver. Set it aside.
  3. Sony Vaio SVE171C11L Motherboard Replacement: paso 3, imagen 1 de 2 Sony Vaio SVE171C11L Motherboard Replacement: paso 3, imagen 2 de 2
    • Remove the three screws securing the hard drive disk in place.
    • Use the blue ribbon attached to the hard drive disk to carefully remove it from laptop. Set it aside.
  4. Sony Vaio SVE171C11L Motherboard Replacement: paso 4, imagen 1 de 1
    • Remove all screws holding the back panel from the laptop.
    • Carefully pull up the back panel to remove it.
  5. Sony Vaio SVE171C11L Motherboard Replacement: paso 5, imagen 1 de 3 Sony Vaio SVE171C11L Motherboard Replacement: paso 5, imagen 2 de 3 Sony Vaio SVE171C11L Motherboard Replacement: paso 5, imagen 3 de 3
    • Remove the cables from the fan and unscrew the heatsink.
    • The heatsink has many metal pieces jutting out from its base and is located under the fan.
    • Carefully disconnect the tabs on the edges of the motherboard.
    • Unscrew the screws holding the motherboard in place. Set them aside.
    • On the underside of the motherboard, disconnect the keyboard from the motherboard.
    • Once ALL cables are disconnected, carefully remove the motherboard.
Conclusión
Edward Briseno
Miembro Desde 09/26/22
896 Reputación
6 Guías creadas
Equipo
CSU Los Angeles, Team 6-3, Adachi Fall 2022 Miembro de CSU Los Angeles, Team 6-3, Adachi Fall 2022
CSULA-ADACHI-F22S6G3
3 Miembros
12 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 4
Ultimos 7 días: 5
Ultimos 30 días: 28
Todo El Tiempo: 369
