Saltar al contenido principal
Sony Vaio SVE171C11L Battery Replacement
Qué necesitas
  1. Sony Vaio SVE171C11L Battery Replacement, Battery: paso 1, imagen 1 de 1
    • Turn the laptop over so its underside is facing upwards and visible.
  2. Sony Vaio SVE171C11L Battery Replacement: paso 2, imagen 1 de 1
    • Once you flip the laptop over, make sure the right tab is pushed upwards to unlock it.
    • Use your left hand to push up the left tab to release the battery.
  3. Sony Vaio SVE171C11L Battery Replacement: paso 3, imagen 1 de 1
    • After the battery is released, locate the small gap where the battery and the shell meet. Then lift the gap up and rotate the battery up and away from yourself.
  4. Sony Vaio SVE171C11L Battery Replacement: paso 4, imagen 1 de 1
    • Pull the battery away.
Conclusión
Edward Briseno
Miembro Desde 09/26/22
896 Reputación
6 Guías creadas
Equipo
CSU Los Angeles, Team 6-3, Adachi Fall 2022 Miembro de CSU Los Angeles, Team 6-3, Adachi Fall 2022
CSULA-ADACHI-F22S6G3
3 Miembros
12 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 3
Ultimos 30 días: 14
Todo El Tiempo: 217
