Saltar al contenido principal
Sony Vaio SVE15112FXS Keyboard Replacement
Qué necesitas
  1. Sony Vaio SVE15112FXS Keyboard Replacement, Keyboard: paso 1, imagen 1 de 1
    • Power laptop off before beginning.
    • Turn the laptop over so that it is positioned top down with the model number facing you.
  2. Sony Vaio SVE15112FXS Keyboard Replacement: paso 2, imagen 1 de 1
    • Use a #0 Phillips screwdriver to remove the two 4.0 mm screws securing the hard drive cover.
    • To avoid losing any parts, we recommend that you place the loose screws on a magnetic project mat.
  3. Sony Vaio SVE15112FXS Keyboard Replacement: paso 3, imagen 1 de 2 Sony Vaio SVE15112FXS Keyboard Replacement: paso 3, imagen 2 de 2
    • To expose the hard drive, remove the cover by sliding it toward you and pulling up on the panel.
  4. Sony Vaio SVE15112FXS Keyboard Replacement: paso 4, imagen 1 de 1
    • Use a #0 Phillips screwdriver to remove the two 4.0 mm screws attaching the hard drive to the laptop.
  5. Sony Vaio SVE15112FXS Keyboard Replacement: paso 5, imagen 1 de 2 Sony Vaio SVE15112FXS Keyboard Replacement: paso 5, imagen 2 de 2
    • Pull the clear plastic ribbon to the left until the mount is detached from the laptop.
    • There will be some resistance as the hard drive is disconnected. If it does not move at all, check that all anchor screws are removed.
    • Lift the hard drive out of the well.
  6. Sony Vaio SVE15112FXS Keyboard Replacement: paso 6, imagen 1 de 1
    • Use a Phillips #0 screwdriver to remove the one 4.0 mm screw next to the model number label.
  7. Sony Vaio SVE15112FXS Keyboard Replacement: paso 7, imagen 1 de 1
    • Use a plastic opening tool to slide the CD-ROM out from the laptop.
  8. Sony Vaio SVE15112FXS Keyboard Replacement: paso 8, imagen 1 de 3 Sony Vaio SVE15112FXS Keyboard Replacement: paso 8, imagen 2 de 3 Sony Vaio SVE15112FXS Keyboard Replacement: paso 8, imagen 3 de 3
    • Slide the "lock" tab upward to unlock the battery before removal.
    • While pushing the "release" tab upward, lift the battery and pull outward to remove it from the laptop.
  9. Sony Vaio SVE15112FXS Keyboard Replacement: paso 9, imagen 1 de 3 Sony Vaio SVE15112FXS Keyboard Replacement: paso 9, imagen 2 de 3 Sony Vaio SVE15112FXS Keyboard Replacement: paso 9, imagen 3 de 3
    • To unsecure the back cover, remove all the case screws using a #0 Phillips screwdriver.
    • Remove the two 9.0 mm screws on each side of the battery.
    • Remove the twelve 8.0 mm long screws alongside the entire back cover.
    • Remove the three 3.0 mm screws inside the battery well.
  10. Sony Vaio SVE15112FXS Keyboard Replacement: paso 10, imagen 1 de 3 Sony Vaio SVE15112FXS Keyboard Replacement: paso 10, imagen 2 de 3 Sony Vaio SVE15112FXS Keyboard Replacement: paso 10, imagen 3 de 3
    • Use a plastic opening tool to carefully pry open the latch points located under the silver plastic trim. Repeat this around the back cover.
    • It may be easiest to start around the CD-ROM bay because there is more room.
    • To avoid damaging the plastic trim and cover, do not force difficult areas and make sure the opening tool is completely under the black plastic cover, not just the silver trim.
    • Lift the back cover upward and away from the laptop.
  11. Sony Vaio SVE15112FXS Keyboard Replacement: paso 11, imagen 1 de 1
    • Gently push the rectangular opening on the CD-ROM well to loosen the keyboard.
  12. Sony Vaio SVE15112FXS Keyboard Replacement: paso 12, imagen 1 de 2 Sony Vaio SVE15112FXS Keyboard Replacement: paso 12, imagen 2 de 2
    • Use a plastic opening tool to pry upward on the keyboard. Only the top of the keyboard is latched.
    • Lift the keyboard toward you and away from the laptop.
  13. Sony Vaio SVE15112FXS Keyboard Replacement: paso 13, imagen 1 de 2 Sony Vaio SVE15112FXS Keyboard Replacement: paso 13, imagen 2 de 2
    • Use a plastic opening tool to disconnect the two ZIF connectors attached to each ribbon. Both are located under the keyboard and have a clear flap that must be lifted upward before removal.
    • Open the white connector attached to the copper ribbon.
    • Open the white connected attached to the black and white striped ribbon.
    • Take care when opening these connectors. The ribbon is anchored underneath the clear flap. Pulling these pieces out of their sockets will make it difficult to reassemble them.
    • Lift the keyboard away from the body of the laptop.
Conclusión
Una persona más ha completado esta guía.
Ashley Bierman
Miembro Desde 09/06/18
1,223 Reputación
5 Guías creadas
Equipo
Ohio State, Team S1-G1, Whitney Fall 2018 Miembro de Ohio State, Team S1-G1, Whitney Fall 2018
OSU-WHITNEY-F18S1G1
2 Miembros
10 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 10
Todo El Tiempo: 470
