Saltar al contenido principal
Sony Vaio SVE15112FXS Hard Drive Replacement
Qué necesitas
  1. Sony Vaio SVE15112FXS Hard Drive Replacement, Hard Drive: paso 1, imagen 1 de 1
    • Power laptop off before beginning.
    • Turn the laptop over so that it is positioned top down with the model number facing you.
  2. Sony Vaio SVE15112FXS Hard Drive Replacement: paso 2, imagen 1 de 1
    • Use a #0 Phillips screwdriver to remove the two 4.0 mm screws securing the hard drive cover.
    • To avoid losing any parts, we recommend that you place the loose screws on a magnetic project mat.
  3. Sony Vaio SVE15112FXS Hard Drive Replacement: paso 3, imagen 1 de 2 Sony Vaio SVE15112FXS Hard Drive Replacement: paso 3, imagen 2 de 2
    • To expose the hard drive, remove the cover by sliding it toward you and pulling up on the panel.
  4. Sony Vaio SVE15112FXS Hard Drive Replacement: paso 4, imagen 1 de 1
    • Use a #0 Phillips screwdriver to remove the two 4.0 mm screws attaching the hard drive to the laptop.
  5. Sony Vaio SVE15112FXS Hard Drive Replacement: paso 5, imagen 1 de 2 Sony Vaio SVE15112FXS Hard Drive Replacement: paso 5, imagen 2 de 2
    • Pull the clear plastic ribbon to the left until the mount is detached from the laptop.
    • There will be some resistance as the hard drive is disconnected. If it does not move at all, check that all anchor screws are removed.
    • Lift the hard drive out of the well.
  6. Sony Vaio SVE15112FXS Hard Drive Replacement: paso 6, imagen 1 de 2 Sony Vaio SVE15112FXS Hard Drive Replacement: paso 6, imagen 2 de 2
    • Use a #0 Phillips screwdriver to remove the four 4.0 mm screws attaching the mount to the hard drive.
    • Slide the hard drive away from the mount until it is completely detached.
    • Take note of how the mount is positioned when attached to the hard drive.
Conclusión
Una persona más ha completado esta guía.
Ashley Bierman
Miembro Desde 09/06/18
1,223 Reputación
5 Guías creadas
Equipo
Ohio State, Team S1-G1, Whitney Fall 2018 Miembro de Ohio State, Team S1-G1, Whitney Fall 2018
OSU-WHITNEY-F18S1G1
2 Miembros
10 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 11
Todo El Tiempo: 693
