Saltar al contenido principal
Sony Vaio SVE111B11L Keyboard Assembly Replacement
Qué necesitas
  1. Sony Vaio SVE111B11L Keyboard Assembly Replacement, Battery: paso 1, imagen 1 de 2 Sony Vaio SVE111B11L Keyboard Assembly Replacement, Battery: paso 1, imagen 2 de 2
    • Remove the charging adaptor. Some charge may still be in the battery or computer. DO NOT touch connectors or copper yellow connector.
    • Locate the battery on the bottom of the computer.
    • Flip the computer so that the battery faces you.
  2. Sony Vaio SVE111B11L Keyboard Assembly Replacement: paso 2, imagen 1 de 1
    • Locate the two latches with the words “lock” and “release” on them.
  3. Sony Vaio SVE111B11L Keyboard Assembly Replacement: paso 3, imagen 1 de 1
    • Push the latches towards each other and lift the battery to remove it.
  4. Sony Vaio SVE111B11L Keyboard Assembly Replacement, Keyboard Assembly: paso 4, imagen 1 de 1
    • Remove the memory door on the bottom of the computer to access the screw for the keyboard.
    • The screws for the memory door do not come out.
  5. Sony Vaio SVE111B11L Keyboard Assembly Replacement: paso 5, imagen 1 de 1
    • Remove the 6.7 mm screw that holds the keyboard assembly in place.
  6. Sony Vaio SVE111B11L Keyboard Assembly Replacement: paso 6, imagen 1 de 1
    • Be careful not to break the keyboard wire connection.
    • Slide the wires out, away from the solder connections.
    • Flip the computer over and open it.
  7. Sony Vaio SVE111B11L Keyboard Assembly Replacement: paso 7, imagen 1 de 3 Sony Vaio SVE111B11L Keyboard Assembly Replacement: paso 7, imagen 2 de 3 Sony Vaio SVE111B11L Keyboard Assembly Replacement: paso 7, imagen 3 de 3
    • Gently pry the keyboard assembly from the screen side, using an opening tool. You will need to lift the keyboard about two inches.
    • Using an opening tool, gently pull out and slightly up on the connector clip.
    • Gently lift the keyboard assembly up and out.
Conclusión
2 personas más completaron esta guía.
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 16
Todo El Tiempo: 1,221
