Saltar al contenido principal
Sony Vaio SVE111B11L Battery Replacement
  1. Sony Vaio SVE111B11L Battery Replacement, Battery: paso 1, imagen 1 de 2 Sony Vaio SVE111B11L Battery Replacement, Battery: paso 1, imagen 2 de 2
    • Remove the charging adaptor. Some charge may still be in the battery or computer. DO NOT touch connectors or copper yellow connector.
    • Locate the battery on the bottom of the computer.
    • Flip the computer so that the battery faces you.
  2. Sony Vaio SVE111B11L Battery Replacement: paso 2, imagen 1 de 1
    • Locate the two latches with the words “lock” and “release” on them.
  3. Sony Vaio SVE111B11L Battery Replacement: paso 3, imagen 1 de 1
    • Push the latches towards each other and lift the battery to remove it.
Conclusión
5 personas más completaron esta guía.
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 3
Ultimos 30 días: 21
Todo El Tiempo: 917
