Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Tienda
  1. Remove cover for the extended battery connector. Use your finger nail or a plastic opening tool to remove it. Remove the two rubber feet at the back of the computer, these can be removed in the same way.
    • Remove cover for the extended battery connector. Use your finger nail or a plastic opening tool to remove it.
    • Remove the two rubber feet at the back of the computer, these can be removed in the same way.
  2. Remove the four 5.6mm  Philips #00 screws located at the top of the computer. Remove the eight 3.6mm Philips #00 screws on the base of the computer.
    • Remove the four 5.6mm Philips #00 screws located at the top of the computer.
    • Remove the eight 3.6mm Philips #00 screws on the base of the computer.
  3. Using a plastic opening tool, pry the plastic casing away from the base of the computer, the remaining clips around the edges can be released using your hands. Leave the side with the USB and audio port until last, then slide the case out and off, so the audio port doesn't get caught.
    • Using a plastic opening tool, pry the plastic casing away from the base of the computer, the remaining clips around the edges can be released using your hands.
    • Leave the side with the USB and audio port until last, then slide the case out and off, so the audio port doesn't get caught.
  4. Gently lift the small, black piece of tape located near the fan.
    • Gently lift the small, black piece of tape located near the fan.
  5. Remove the three 4.2mm Philips #0 screws located at the top of the battery. Simply lift the battery away from the computer.
    • Remove the three 4.2mm Philips #0 screws located at the top of the battery.
    • Simply lift the battery away from the computer.
  6. Using the flat end of the spudger, pry the edge of the ribbon wire on top of the memory card so it is loose enough to detach from the memory card. Using the flat end of the spudger, pry the edge of the ribbon wire on top of the memory card so it is loose enough to detach from the memory card.
    • Using the flat end of the spudger, pry the edge of the ribbon wire on top of the memory card so it is loose enough to detach from the memory card.
  7. Lift up the small, square, black piece of tape that covers the screw on the memory card. Using the philips head 00, unscrew the screw holding the memory card in place. Once the screw is out, the memory card should lift up easily.
    • Lift up the small, square, black piece of tape that covers the screw on the memory card.
    • Using the philips head 00, unscrew the screw holding the memory card in place.
    • Once the screw is out, the memory card should lift up easily.
Conclusión
Hey Alex!
Do you know if the fan is the same for the Sony Viao Pro 11 as the one for the Viao Pro 13?.
I can only see info for the fan for the 13.
Thanks!..
Raul Eduardo - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 7
Todo El Tiempo: 1,464
