Introducción
If your hard drive is broken or you want to upgrade it, follow these instructions to remove it. Replacing or repairing the hard drive requires first removing the keyboard.
CAUTION: Static electricity in your body can ruin you computer. Use an anti-static wristband.
Qué necesitas
The battery is located on the left side of the laptop, as shown by the red circle.
Make sure the laptop is disconnected and turned completely off.
Use your Philips #00 screwdriver to unscrew the small screw counterclockwise. This screw is for the audio/visual jacks on the left side of the laptop.
The hard drive is the metal box in the middle. Use your Philips Head screwdriver to remove the four screws that attach the cage to the motherboard.
The Hard Drive box is now unfastened. You can free it from the laptop by pulling up, but be careful because it is held in place by the surrounding metal pieces so a little strength, yet care, is needed. When free, do not immediately remove it, there is a ribbon cable connecting it to the laptop.
Una persona más ha completado esta guía.
