Saltar al contenido principal
Sony Vaio PCG-F360 Hard Drive Replacement
Qué necesitas
  1. Sony Vaio PCG-F360 Hard Drive Replacement, Battery: paso 1, imagen 1 de 1
    • Position the laptop screen-side down as shown.
    • In this position the battery housing will be located on the right hand side.
  2. Sony Vaio PCG-F360 Hard Drive Replacement: paso 2, imagen 1 de 1
    • Lift the panel up and then out to gain access to the battery.
  3. Sony Vaio PCG-F360 Hard Drive Replacement: paso 3, imagen 1 de 1
    • Use the indentations to pull the old battery out.
  4. Sony Vaio PCG-F360 Hard Drive Replacement: paso 4, imagen 1 de 1
    • The battery is now removed and it is safe to move on to uninstalling other components.
  5. Sony Vaio PCG-F360 Hard Drive Replacement, Keyboard: paso 5, imagen 1 de 3 Sony Vaio PCG-F360 Hard Drive Replacement, Keyboard: paso 5, imagen 2 de 3 Sony Vaio PCG-F360 Hard Drive Replacement, Keyboard: paso 5, imagen 3 de 3
    • There are two screws on the left hand side of the laptop near the IR (Infared remote) receiver (see image). Remove them using a Phillips #00 Screwdriver.
    • Slide the speaker panel towards the left, then carefully flip it over onto the keyboard.
    • Make sure not to pull the speaker panel away from the computer just yet - it is still connected!
  6. Sony Vaio PCG-F360 Hard Drive Replacement: paso 6, imagen 1 de 3 Sony Vaio PCG-F360 Hard Drive Replacement: paso 6, imagen 2 de 3 Sony Vaio PCG-F360 Hard Drive Replacement: paso 6, imagen 3 de 3
    • On the inside of the speaker panel, using a spudger, push the beige tab in the direction of the ribbon. It should only move a small amount.
    • Remove the ribbon by gently pulling on it, there should be little or no resistance.
    • Now the speaker panel can be set aside.
  7. Sony Vaio PCG-F360 Hard Drive Replacement: paso 7, imagen 1 de 2 Sony Vaio PCG-F360 Hard Drive Replacement: paso 7, imagen 2 de 2
    • Remove the metal screw that will be located at the red circle.
    • Pull on the green strip, and the keyboard should come free easily.
  8. Sony Vaio PCG-F360 Hard Drive Replacement, Hard Drive: paso 8, imagen 1 de 2 Sony Vaio PCG-F360 Hard Drive Replacement, Hard Drive: paso 8, imagen 2 de 2
    • We had a bit of a surprise when we opened our Sony. The hard drive was missing! While this is common practice when disposing of or selling a computer, it means that we're unable to show you what the hard drive looks inside the laptop.
    • If a hard drive was present, it would attach to the motherboard by the shown connector.
Conclusión
ahintz
Miembro Desde 04/21/10
28 Reputación
8 Guías creadas
Equipo
Cal Poly, Team 16-3, Maness Spring 2010 Miembro de Cal Poly, Team 16-3, Maness Spring 2010
CPSU-MANESS-S10S16G3
3 Miembros
8 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 2
Ultimos 30 días: 2
Todo El Tiempo: 2,931
