Saltar al contenido principal
Sony Vaio PCG-F360 Floppy Drive Replacement
  1. Sony Vaio PCG-F360 Floppy Drive Replacement, Battery: paso 1, imagen 1 de 1
    • Position the laptop screen-side down as shown.
    • In this position the battery housing will be located on the right hand side.
  2. Sony Vaio PCG-F360 Floppy Drive Replacement: paso 2, imagen 1 de 1
    • Lift the panel up and then out to gain access to the battery.
  3. Sony Vaio PCG-F360 Floppy Drive Replacement: paso 3, imagen 1 de 1
    • Use the indentations to pull the old battery out.
  4. Sony Vaio PCG-F360 Floppy Drive Replacement: paso 4, imagen 1 de 1
    • The battery is now removed and it is safe to move on to uninstalling other components.
  5. Sony Vaio PCG-F360 Floppy Drive Replacement, Floppy Drive: paso 5, imagen 1 de 2 Sony Vaio PCG-F360 Floppy Drive Replacement, Floppy Drive: paso 5, imagen 2 de 2
    • With one hand slide and hold the tab shown.
    • With your other hand, pull the floppy drive out of the floppy drive bay.
    • To replace the floppy drive, simply slide the drive into the slot until it clicks.
Conclusión
ahintz
Miembro Desde 04/21/10
28 Reputación
8 Guías creadas
Equipo
Cal Poly, Team 16-3, Maness Spring 2010 Miembro de Cal Poly, Team 16-3, Maness Spring 2010
CPSU-MANESS-S10S16G3
3 Miembros
8 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 4
Todo El Tiempo: 2,779
