Saltar al contenido principal
Sony Vaio VGN-FS640 RAM Cover Replacement
Qué necesitas
  1. Sony Vaio VGN-FS640 RAM Cover Replacement, Battery: paso 1, imagen 1 de 1
    • Lay the closed laptop on its screen so the bottom is facing towards you.
  2. Sony Vaio VGN-FS640 RAM Cover Replacement: paso 2, imagen 1 de 1
    • Push both latches towards the center of the battery.
  3. Sony Vaio VGN-FS640 RAM Cover Replacement: paso 3, imagen 1 de 2 Sony Vaio VGN-FS640 RAM Cover Replacement: paso 3, imagen 2 de 2
    • Revome the battery by pushing it away from the laptop.
    • Set the battery away from the laptop.
  4. Sony Vaio VGN-FS640 RAM Cover Replacement, RAM Cover: paso 4, imagen 1 de 2 Sony Vaio VGN-FS640 RAM Cover Replacement, RAM Cover: paso 4, imagen 2 de 2
    • With the bottom of the laptop facing up, locate the RAM cover.
    • The RAM is covered by the panel with four columns of vents.
    • Locate the screw (Length: 4.8 mm) holding down the panel, which is near the edge of the laptop. Unscrew it with your phillips #0 screwdriver.
  5. Sony Vaio VGN-FS640 RAM Cover Replacement: paso 5, imagen 1 de 3 Sony Vaio VGN-FS640 RAM Cover Replacement: paso 5, imagen 2 de 3 Sony Vaio VGN-FS640 RAM Cover Replacement: paso 5, imagen 3 de 3
    • Use your fingers to slide the cover away from the laptop. (It will only slide a few millimeters)
    • Once the panel is out of its locked position, it can be lifted out without any resistance.
Conclusión
Brian Marchini
Miembro Desde 04/15/10
293 Reputación
2 Guías creadas
Equipo
Cal Poly, Team 24-32, Regan Spring 2010 Miembro de Cal Poly, Team 24-32, Regan Spring 2010
CPSU-REGAN-S10S24G32
4 Miembros
16 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 5
Ultimos 30 días: 16
Todo El Tiempo: 4,813
