Introducción
This guide will show you how to replace the Hard Drive on your Sony Vaio PCG-7A2L.
Partes
No se requieren partes.
  1. Lay the closed laptop on its screen so the bottom is facing towards you.
    • Lay the closed laptop on its screen so the bottom is facing towards you.
  2. Push both latches towards the center of the battery.
    • Push both latches towards the center of the battery.
  3. ¡Envío gratuito para todos los pedidos de más de USD100 o que contengan un Pro Tech Toolkit!
    Visita Nuestra Tienda
  4. Revome the battery by pushing it away from the laptop. Set the battery away from the laptop.
    • Revome the battery by pushing it away from the laptop.
    • Set the battery away from the laptop.
  5. Locate and remove the screw (Length: 7.7mm) for the hard drive cover. Slide the cover until it is free from the laptop case. Lift the cover to remove.
    • Locate and remove the screw (Length: 7.7mm) for the hard drive cover.
    • Slide the cover until it is free from the laptop case.
    • Lift the cover to remove.
  6. Locate and remove the four screws (Length: 7.7mm) holding the Hard Drive tray in place. Using the tab on the tray, slide the Hard Drive away from the main body of the laptop. The Hard Drive should now be disconnected.
    • Locate and remove the four screws (Length: 7.7mm) holding the Hard Drive tray in place.
    • Using the tab on the tray, slide the Hard Drive away from the main body of the laptop.
    • The Hard Drive should now be disconnected.
    • Lift the drive out with the tab on the tray.
Conclusión
2 personas más completaron esta guía.
Matt McCarty
Miembro Desde 15/04/10
220 Reputación
2 Guías creadas
Equipo
Cal Poly, Team 24-32, Regan Spring 2010 Miembro de Cal Poly, Team 24-32, Regan Spring 2010
CPSU-REGAN-S10S24G32
4 Miembros
8 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 1
Últimos 30 Días: 3
Todo El Tiempo: 9,926
