Introducción
In this guide we will be taking out and replacing the RAM Sticks.
Partes
No se requieren partes.
  1. Use a Phillips #00 screwdriver to unscrew the single RAM cover screw.
    • Use a Phillips #00 screwdriver to unscrew the single RAM cover screw.
  2. Pull the cover of the RAM sticks up.
    • Pull the cover of the RAM sticks up.
  3. ¡Envío gratuito para todos los pedidos de más de USD100 o que contengan un Pro Tech Toolkit!
    Visita Nuestra Tienda
  4. Pull apart the metal sides on the sides of the top RAM stick to pop it up. Repeat that process with the bottom RAM stick.
    • Pull apart the metal sides on the sides of the top RAM stick to pop it up.
    • Repeat that process with the bottom RAM stick.
  5. Remove both RAM sticks. Take care removing the RAM sticks as they are fragile. Take care removing the RAM sticks as they are fragile.
    • Remove both RAM sticks.
    • Take care removing the RAM sticks as they are fragile.
Conclusión
Congratulations!
Michael Miller
Miembro Desde 21/09/18
161 Reputación
1 Guía escrita
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 2
Últimos 30 Días: 8
Todo El Tiempo: 55
