Introducción
Installing or replacing a hard drive is a fairly simple procedure. It only involves a total of 6 screws and up to a 320 GB HDD.
Partes
  1. First, locate the hard drive slot on the under side of the laptop. Unscrew the screws using your Phillips #00 screwdriver. Set the two screws aside so you can screw them in later on when you're finished.
    • First, locate the hard drive slot on the under side of the laptop.
    • Unscrew the screws using your Phillips #00 screwdriver.
    • Set the two screws aside so you can screw them in later on when you're finished.
    • This should reveal a small metallic place holder that your hard drive belongs.
  2. ¡Envío gratuito para todos los pedidos de más de USD100 o que contengan un Pro Tech Toolkit!
    Visita Nuestra Tienda
  3. Unscrew the 4 hard drive bracket screws. Once the screw is undone you can pull the place holder back to find the  slot where the actual hard drive belongs.
    • Unscrew the 4 hard drive bracket screws.
    • Once the screw is undone you can pull the place holder back to find the slot where the actual hard drive belongs.
    • Remember to set aside the screw so you can correctly install the hard drive.
Conclusión
The installation/replacement is a very easy task that can be done by anyone.
Alberto Rosas
Miembro Desde 21/09/18
143 Reputación
1 Guía escrita
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 3
Últimos 30 Días: 5
Todo El Tiempo: 46
