Introducción
This guide will show and demonstrate how to remove and replace the battery in a Sony Vaio PCG-71C11L laptop.
Herramientas
Partes
No se requieren partes.
  1. Slide the switch with the word "lock" above it to the unlocked position.
    • Slide the switch with the word "lock" above it to the unlocked position.
  2. Hold the switch that says "Release" to the open position while pulling up on the side of the battery with the groove. Once the battery is flipped up, it can easily be removed.
    • Hold the switch that says "Release" to the open position while pulling up on the side of the battery with the groove. Once the battery is flipped up, it can easily be removed.
Conclusión
charles cochran
Miembro Desde 21/09/18
101 Reputación
1 Guía escrita
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 0
Últimos 30 Días: 29
Todo El Tiempo: 34
