Saltar al contenido principal
Sony Vaio VGN-NW240F (PCG-7184L) RAM Replacement
Qué necesitas
  1. Sony Vaio VGN-NW240F (PCG-7184L) RAM Replacement, Battery: paso 1, imagen 1 de 1
    • Power off the laptop.
    • Unplug the charging cable and any other cables plugged into the laptop.
    • Failure to remove or unplug any cables could result in electric shock.
    • Turn the laptop over so that the back panel is facing upwards.
  2. Sony Vaio VGN-NW240F (PCG-7184L) RAM Replacement: paso 2, imagen 1 de 1
    • Locate two switches above the battery that lock it into place.
    • Push the left-hand switch, that says "lock" above it, so that it is unlocked.
  3. Sony Vaio VGN-NW240F (PCG-7184L) RAM Replacement: paso 3, imagen 1 de 1
    • Push and hold the right-hand switch, which says "release" above it, and lift the battery up out of its place.
  4. Sony Vaio VGN-NW240F (PCG-7184L) RAM Replacement, RAM: paso 4, imagen 1 de 1
    • Unscrew the highlighted 5.3mm Phillips #1 screw from the middle of the back panel.
    • The screw cannot be removed fully and only loosens. Loosen the screw until the panel does not raise up anymore.
  5. Sony Vaio VGN-NW240F (PCG-7184L) RAM Replacement: paso 5, imagen 1 de 1
    • Using a spudger, lift up and remove the loosened panel.
    • If the panel does not lift up with a moderate amount of force, do NOT try to force it out. Make sure that the screw is fully loosened before attempting again.
  6. Sony Vaio VGN-NW240F (PCG-7184L) RAM Replacement: paso 6, imagen 1 de 1
    • Locate the two metal levers on either side of the memory chip.
    • Pull back both levers simultaneously and if done correctly, the RAM should release and lift up at an angle.
  7. Sony Vaio VGN-NW240F (PCG-7184L) RAM Replacement: paso 7, imagen 1 de 1
    • Gently remove the RAM chip from its placement.
    • If you want to remove the second stick of RAM as well, do so by following the previous step.
Conclusión
2 personas más completaron esta guía.
Brian Luu
Miembro Desde 04/08/14
720 Reputación
3 Guías creadas
Equipo
Cal Poly, Team 9-17, Regan Spring 2014 Miembro de Cal Poly, Team 9-17, Regan Spring 2014
CPSU-REGAN-S14S9G17
4 Miembros
18 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 5
Ultimos 30 días: 23
Todo El Tiempo: 5,423
