Saltar al contenido principal
Qué necesitas
Este desmontaje no es una guía de reparación. Para reparar tu Sony Vaio PCG-6J2L, utiliza nuestros manuales de servicio .
  1. Sony Vaio VGN-SZ120P Teardown, Sony Vaio VGN-SZ120P Teardown: paso 1, imagen 1 de 2 Sony Vaio VGN-SZ120P Teardown, Sony Vaio VGN-SZ120P Teardown: paso 1, imagen 2 de 2
    • Turn the laptop upside down.
    • Locate the battery.
    • Unlock the battery by shifting the 'lock' slide to the 'unlock' position on the underside and back of the system.
    • Hold the release on the right side and remove the battery out carefully.
  2. Sony Vaio VGN-SZ120P Teardown: paso 2, imagen 1 de 3 Sony Vaio VGN-SZ120P Teardown: paso 2, imagen 2 de 3 Sony Vaio VGN-SZ120P Teardown: paso 2, imagen 3 de 3
    • Remove the four screws from the heat sink panel with the phillips screwdriver.
    • Unscrew the two screws from the memory panel with the phillips screwdriver.
    • Remove both panels and set aside.
    • Be careful with the heatsink, as this can be messy if handled improperly. It is a copper heat pipe.
  3. Sony Vaio VGN-SZ120P Teardown: paso 3, imagen 1 de 3 Sony Vaio VGN-SZ120P Teardown: paso 3, imagen 2 de 3 Sony Vaio VGN-SZ120P Teardown: paso 3, imagen 3 de 3
    • Lift the film covering to reveal the memory modules with the tweezers.
    • Pull the tabs on both sides of the RAM away from the module. The module will pop up.
    • Repeat these step for the other RAM module located above the RAM module previously removed and set aside.
  4. Sony Vaio VGN-SZ120P Teardown: paso 4, imagen 1 de 1
    • Using a Philips screw driver, unscrew the rear keyboard screw from the bottom of the laptop.
  5. Sony Vaio VGN-SZ120P Teardown: paso 5, imagen 1 de 2 Sony Vaio VGN-SZ120P Teardown: paso 5, imagen 2 de 2
    • Push the tabs shown on both sides and the keyboard will pop up.
    • A small flat-head might help you push the tabs.
    • Move the keyboard toward the mouse pad and gently pull up.
  6. Sony Vaio VGN-SZ120P Teardown: paso 6, imagen 1 de 2 Sony Vaio VGN-SZ120P Teardown: paso 6, imagen 2 de 2
    • Caution: there is a ribbon cable attached to the keyboard. It will break easily.
    • Gently disconnect the ribbon cable by sliding down the tabs.
    • Gently take out the keyboard.
  7. Sony Vaio VGN-SZ120P Teardown: paso 7, imagen 1 de 2 Sony Vaio VGN-SZ120P Teardown: paso 7, imagen 2 de 2
    • Unscrew the two securing screws indicated.
    • Carefully lift the heatsink out of the system with the tweezers and set it aside.
  8. Sony Vaio VGN-SZ120P Teardown: paso 8, imagen 1 de 3 Sony Vaio VGN-SZ120P Teardown: paso 8, imagen 2 de 3 Sony Vaio VGN-SZ120P Teardown: paso 8, imagen 3 de 3
    • Caution: DO NOT touch the gold connectors on the cpu, as this may damage your processor.
    • Turn the securing screw on top of the CPU housing bracket counter-clockwise on the unlock position.
    • Gently lift the CPU out of the system with tweezers and set aside in a safe place.
  9. Sony Vaio VGN-SZ120P Teardown: paso 9, imagen 1 de 3 Sony Vaio VGN-SZ120P Teardown: paso 9, imagen 2 de 3 Sony Vaio VGN-SZ120P Teardown: paso 9, imagen 3 de 3
    • Remove the three screws from the front mouse panel.
    • Lift the mouse assembly just enough to access the connecting ribbon cable.
    • Lift the ribbon cable lock to remove the cable.
    • Carefully remove the mouse panel assembly and set aside.
  10. Sony Vaio VGN-SZ120P Teardown: paso 10, imagen 1 de 2 Sony Vaio VGN-SZ120P Teardown: paso 10, imagen 2 de 2
    • Remove the securing screw on the bottom left of the optical drive.
    • Carefully slide the optical drive to the right.
    • The IDE connector on the left will pop out.
  11. Sony Vaio VGN-SZ120P Teardown: paso 11, imagen 1 de 3 Sony Vaio VGN-SZ120P Teardown: paso 11, imagen 2 de 3 Sony Vaio VGN-SZ120P Teardown: paso 11, imagen 3 de 3
    • Disconnect the antennae from the wireless card.
    • Pull back the tabs on the right of the wireless card until the card disconnects and pops up.
    • Remove the wireless card and set aside.
  12. Sony Vaio VGN-SZ120P Teardown: paso 12, imagen 1 de 3 Sony Vaio VGN-SZ120P Teardown: paso 12, imagen 2 de 3 Sony Vaio VGN-SZ120P Teardown: paso 12, imagen 3 de 3
    • Remove the four screws from the underside of the computer. These screws are located underneath where the battery sits and secure the top keyboard panel.
    • To remove the panel below the screen, press up on the two tabs holding the panel in and lift up. The panel should pop off.
    • Before proceeding, remove all black tape holding down wires and other cabling.
  13. Sony Vaio VGN-SZ120P Teardown: paso 13, imagen 1 de 2 Sony Vaio VGN-SZ120P Teardown: paso 13, imagen 2 de 2
    • First pop off the antenna using a pair of tweezers.
    • Use a Philips screw driver to unscrew the screw holding the board in place.
    • Remove the board using a pair of tweezers.
  14. Sony Vaio VGN-SZ120P Teardown: paso 14, imagen 1 de 1
    • Remove the seven philips screws holding the speaker assembly in place.
    • Disconnect the ribbon cable located at the top left corner of the assembly.
  15. Sony Vaio VGN-SZ120P Teardown: paso 15, imagen 1 de 2 Sony Vaio VGN-SZ120P Teardown: paso 15, imagen 2 de 2
    • Caution: Be careful of snags when pulling up assembly and speakers.
    • To remove the VGA cable, lift up on the metal bracket and gently lift the connector off the logic board.
    • To remove the webcam cable, lift up the connector from the logic board gently.
  16. Sony Vaio VGN-SZ120P Teardown: paso 16, imagen 1 de 1
    • This is where your Hard Drive is located.
    • Remove the three harddrive securing screws.
    • The Serial ATA (SATA) hard drive is located where the yellow box indicates in the picture.
  17. Sony Vaio VGN-SZ120P Teardown: paso 17, imagen 1 de 2 Sony Vaio VGN-SZ120P Teardown: paso 17, imagen 2 de 2
    • Remove all screws holding the keyboard tray to the laptop.
    • Lift the cover off the console and set aside.
  18. Sony Vaio VGN-SZ120P Teardown: paso 18, imagen 1 de 1
    • Remove bluetooth, speaker, webcam assembly. This is one unit and will come out together.
  19. Sony Vaio VGN-SZ120P Teardown: paso 19, imagen 1 de 3 Sony Vaio VGN-SZ120P Teardown: paso 19, imagen 2 de 3 Sony Vaio VGN-SZ120P Teardown: paso 19, imagen 3 de 3
    • Unscrew the four securing screws, two on each side of the LCD.
    • Carefully remove the LCD
  20. Sony Vaio VGN-SZ120P Teardown: paso 20, imagen 1 de 1
    • Remove all the screws securing the keyboard tray.
    • Remove keyboard tray.
  21. Sony Vaio VGN-SZ120P Teardown: paso 21, imagen 1 de 2 Sony Vaio VGN-SZ120P Teardown: paso 21, imagen 2 de 2
    • Caution: When removing the fan, be careful to not tear the attached ribbon cable.
    • Unscrew and remove the internal fan.
    • Unscrew and remove the logic board from the backing.
David Hoyt
Miembro Desde 04/09/10
4,023 Reputación
43 Guías creadas
Equipo
Cal Poly, Team 25-89, Amido Spring 2010 Miembro de Cal Poly, Team 25-89, Amido Spring 2010
CPSU-AMIDO-S10S25G89
4 Miembros
63 Guías creadas
2 comentarios
Does this work with the PCG 9J5L
frederick200147 - Contestar
Extremely similar to PCG-6Q2L, one thing to note is that the HDD in this unit was glued to the SATA connector, it can be a little tricky to remove but can be done if you go slow enough.
Myles B - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 15
Ultimos 30 días: 43
Todo El Tiempo: 39,138
