Saltar al contenido principal
Introducción
Use this guide to assist you in replacing your laptop's optical drive.
Hazards
Keep out of reach of children and pets.
DO NOT attempt to teardown or repair your device under the influence of drugs or alcohol.
DO NOT ingest any parts of the system.
Use the correct tools as stated in the tools section.
DO NOT touch any gold connectors on interior or exterior of the system.
Make sure system is unplugged and turned off before performing any maintenance on the system.
Partes
No se especificaron partes.
  1. Sony Vaio PCG-6J2L Optical Drive Replacement, Battery: paso 1, imagen 1 de 1
    • Set the computer display-side down.
    • Unlock the battery by sliding the port-side latch to the 'unlock' position.
  2. Sony Vaio PCG-6J2L Optical Drive Replacement: paso 2, imagen 1 de 1
    • On the opposite side of the battery, press the release latch and slide the battery away from the main body to remove.
  3. Sony Vaio PCG-6J2L Optical Drive Replacement, Keyboard: paso 3, imagen 1 de 1
    • Ignore the removal of the heat sink and memory panels as depicted. They do not need to be removed for the completion of this guide.
    • Remove the Torx security screw near the center of the battery-side edge.
  4. Sony Vaio PCG-6J2L Optical Drive Replacement: paso 4, imagen 1 de 2 Sony Vaio PCG-6J2L Optical Drive Replacement: paso 4, imagen 2 de 2
    • Press the tabs on each side of the display-side of the keyboard with the flat edge of a spudger.
    • Pull the keyboard toward the mouse pad and gently lift up.
  5. Sony Vaio PCG-6J2L Optical Drive Replacement: paso 5, imagen 1 de 2 Sony Vaio PCG-6J2L Optical Drive Replacement: paso 5, imagen 2 de 2
    • The keyboard is still attached by ribbon cable, don't try to remove the keyboard entirely yet.
    • Disconnect the ribbon cable by pressing the tabs on either side of the connector. Pull the cable out parallel to the connector.
    • Remove the keyboard.
  6. Sony Vaio PCG-6J2L Optical Drive Replacement, Mouse Assembly: paso 6, imagen 1 de 1
    • Turn the laptop upside down.
    • Remove the three screws from the front mouse panel located on the bottom of the laptop.
    • Carefully flip the laptop back over. Remove three more screws from the top securing the panel. A ribbon cable will still be attached to the panel when you remove it.
  7. Sony Vaio PCG-6J2L Optical Drive Replacement: paso 7, imagen 1 de 2 Sony Vaio PCG-6J2L Optical Drive Replacement: paso 7, imagen 2 de 2
    • Lift the mouse assembly just enough to access the connecting ribbon cable.
    • Lift the ribbon cable lock to remove the cable.
    • Carefully remove the mouse panel assembly and set aside.
  8. Sony Vaio PCG-6J2L Optical Drive Replacement, Optical Drive: paso 8, imagen 1 de 1
    • Remove the securing screw on the bottom left of the optical drive.
  9. Sony Vaio PCG-6J2L Optical Drive Replacement: paso 9, imagen 1 de 1
    • Carefully slide the optical drive out right.
    • The IDE connector on the left will pop out.
Conclusión
5 personas más completaron esta guía.
David Hoyt
Miembro Desde 09/04/10
3,921 Reputación
43 Guías creadas
Equipo
Cal Poly, Team 25-89, Amido Spring 2010 Miembro de Cal Poly, Team 25-89, Amido Spring 2010
CPSU-AMIDO-S10S25G89
4 Miembros
52 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 15
Todo El Tiempo: 5,252
