Saltar al contenido principal
Sony Vaio VGN-SZ120P Memory Replacement
Qué necesitas
  1. Sony Vaio VGN-SZ120P Memory Replacement, Battery: paso 1, imagen 1 de 1
    • Set the computer display-side down.
    • Unlock the battery by sliding the port-side latch to the 'unlock' position.
  2. Sony Vaio VGN-SZ120P Memory Replacement: paso 2, imagen 1 de 1
    • On the opposite side of the battery, press the release latch and slide the battery away from the main body to remove.
  3. Sony Vaio VGN-SZ120P Memory Replacement, Memory: paso 3, imagen 1 de 2 Sony Vaio VGN-SZ120P Memory Replacement, Memory: paso 3, imagen 2 de 2
    • Unscrew the two memory panel screws and set the panel aside.
    • Ignore the removal of the heatsink panel. This does not need to be removed for RAM module access.
  4. Sony Vaio VGN-SZ120P Memory Replacement: paso 4, imagen 1 de 3 Sony Vaio VGN-SZ120P Memory Replacement: paso 4, imagen 2 de 3 Sony Vaio VGN-SZ120P Memory Replacement: paso 4, imagen 3 de 3
    • Lift the film covering to reveal the memory module with the tweezers.
    • Pull the tabs on both sides of the RAM away from the module. The module will pop up.
    • Repeat this step for the other RAM module located directly above the memory module just removed.
Conclusión
Una persona más ha completado esta guía.
Ryan
Miembro Desde 04/11/10
154 Reputación
2 Guías creadas
Equipo
Cal Poly, Team 25-89, Amido Spring 2010 Miembro de Cal Poly, Team 25-89, Amido Spring 2010
CPSU-AMIDO-S10S25G89
4 Miembros
63 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 3
Todo El Tiempo: 4,943
