Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Tienda
Introducción
The optical drive needs to be replaced when it stops reading discs. This is a guide to replace the optical drive of a Sony Vaio PCG-61A12L.
Partes
No se especificaron partes.
  1. Unlock the battery by sliding the lock upwards.
    • Unlock the battery by sliding the lock upwards.
  2. Slide the release upwards and lift out the battery to remove. Once battery is removed, long press the Power button for 30-60s and discharge any remaining power inside of the computer.
    • Slide the release upwards and lift out the battery to remove.
    • Once battery is removed, long press the Power button for 30-60s and discharge any remaining power inside of the computer.
    • Put on the ESD bracelet, making sure the metal circle is touching your skin. Remove the alligator clip from the other end of the bracelet and insert the jack into the ground plug of an active electrical outlet. (the round hole). Do not move forward until you are grounded.
  3. SALTEA LA ACTUALIZACIÓN
    Ahorra reparando con un kit todo en uno.
    Compra Kits de Reparación
  4. Using the Phillips #1 screwdriver, unscrew the 6.5 mm screw. Using the Phillips #1 screwdriver, unscrew the 6.5 mm screw.
    • Using the Phillips #1 screwdriver, unscrew the 6.5 mm screw.
  5. Grab and slide out the optical drive to remove.
    • Grab and slide out the optical drive to remove.
Conclusión
Ramon Ogaz
Miembro Desde 25/09/17
104 Reputación
1 Guía escrita
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 4
Ultimos 30 días: 17
Todo El Tiempo: 531
