Introducción
The optical disc drive allows your laptop to read and play discs. This is a guide to help you replace the component if you encounter functionality issues.
Qué necesitas
Turn the device over onto its back, where the battery is at the top of the device. Slide the "lock" switch to the right.
The hard drive panel is located in the bottom right corner of the device.
Remove the 5mm screws with the PH0 screwdriver.
Remove the 3mm screws with the PH0 screwdriver.
