Saltar al contenido principal
Sony Vaio PCG-61411L Battery Replacement
  1. Sony Vaio PCG-61411L Battery Replacement, Battery: paso 1, imagen 1 de 3 Sony Vaio PCG-61411L Battery Replacement, Battery: paso 1, imagen 2 de 3 Sony Vaio PCG-61411L Battery Replacement, Battery: paso 1, imagen 3 de 3
    • Be sure to disconnect the device charger and power down the device before beginning.
    • Turn the device over onto its back, where the battery is at the top of the device. Slide the "lock" switch to the right.
  2. Sony Vaio PCG-61411L Battery Replacement: paso 2, imagen 1 de 3 Sony Vaio PCG-61411L Battery Replacement: paso 2, imagen 2 de 3 Sony Vaio PCG-61411L Battery Replacement: paso 2, imagen 3 de 3
    • Slide the "release" switch to the left and gently lift the battery up to remove it.
    • Completely remove the battery from the device.
Conclusión
Sean Lyon
Miembro Desde 03/01/18
381 Reputación
3 Guías creadas
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 9
Todo El Tiempo: 863
