Saltar al contenido principal
Sony Vaio VGN-TXN25N Keyboard Replacement
Qué necesitas
  1. Sony Vaio VGN-TXN25N Keyboard Replacement, Keyboard: paso 1, imagen 1 de 1
    • Take out the screw in the center of the computer.
  2. Sony Vaio VGN-TXN25N Keyboard Replacement: paso 2, imagen 1 de 1
    • Flip the computer right side up.
    • Open screen so that keyboard is visible.
  3. Sony Vaio VGN-TXN25N Keyboard Replacement: paso 3, imagen 1 de 2 Sony Vaio VGN-TXN25N Keyboard Replacement: paso 3, imagen 2 de 2
    • Use a plastic opening tool to gently lift the keyboard at a corner.
    • Make sure you get below the keyboard itself and not just the keys.
    • Slide the tool around the perimeter of the keyboard and it will start to lift.
  4. Sony Vaio VGN-TXN25N Keyboard Replacement: paso 4, imagen 1 de 2 Sony Vaio VGN-TXN25N Keyboard Replacement: paso 4, imagen 2 de 2
    • Do not pull the keyboard away from the computer. There is a ribbon cord attaching the keyboard to the computer.
    • Once the keyboard has been lifted at a few edges, lift the keyboard with both hands.
  5. Sony Vaio VGN-TXN25N Keyboard Replacement: paso 5, imagen 1 de 3 Sony Vaio VGN-TXN25N Keyboard Replacement: paso 5, imagen 2 de 3 Sony Vaio VGN-TXN25N Keyboard Replacement: paso 5, imagen 3 de 3
    • Locate the ribbon cord behind the keyboard.
    • Locate a brown clamp attaching the keyboard to the computer.
    • Use a plastic opening tool to lift the clamp and release the cable.
    • Now the keyboard can be pulled away entirely.
Conclusión
Austen
Miembro Desde 04/03/12
32 Reputación
2 Guías creadas
Equipo
Cal Poly, Team 5-3, Forte Spring 2012 Miembro de Cal Poly, Team 5-3, Forte Spring 2012
CPSU-FORTE-S12S5G3
5 Miembros
12 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 5
Ultimos 30 días: 16
Todo El Tiempo: 2,073
