Saltar al contenido principal
Sony Vaio VGN-TXN25N Display Screen Replacement
Qué necesitas
  1. Sony Vaio VGN-TXN25N Display Screen Replacement, Display Screen: paso 1, imagen 1 de 2 Sony Vaio VGN-TXN25N Display Screen Replacement, Display Screen: paso 1, imagen 2 de 2
    • Place the computer on a flat surface with the top facing up.
    • Open the screen.
  2. Sony Vaio VGN-TXN25N Display Screen Replacement: paso 2, imagen 1 de 3 Sony Vaio VGN-TXN25N Display Screen Replacement: paso 2, imagen 2 de 3 Sony Vaio VGN-TXN25N Display Screen Replacement: paso 2, imagen 3 de 3
    • Locate the rubber screw caps at the two bottom corners of the screen.
    • Use your finger to remove the rubber screw caps.
  3. Sony Vaio VGN-TXN25N Display Screen Replacement: paso 3, imagen 1 de 2 Sony Vaio VGN-TXN25N Display Screen Replacement: paso 3, imagen 2 de 2
    • Locate the two screws, one on each bottom corner.
    • Unscrew the screws with a Phillips head size #0 screwdriver.
    • Keep track of the screws. They are small and easy to misplace.
  4. Sony Vaio VGN-TXN25N Display Screen Replacement: paso 4, imagen 1 de 3 Sony Vaio VGN-TXN25N Display Screen Replacement: paso 4, imagen 2 de 3 Sony Vaio VGN-TXN25N Display Screen Replacement: paso 4, imagen 3 de 3
    • Use a plastic opening tool to gently lift the plastic casing that borders the screen.
    • Pop off the casing by working the tool around the outside of it.
    • Wiggling the tool may be required. The casing could be fitted snugly.
  5. Sony Vaio VGN-TXN25N Display Screen Replacement: paso 5, imagen 1 de 3 Sony Vaio VGN-TXN25N Display Screen Replacement: paso 5, imagen 2 de 3 Sony Vaio VGN-TXN25N Display Screen Replacement: paso 5, imagen 3 de 3
    • Carefully flip down the screen so it rests on the keyboard.
    • Locate the wire connector on the back of the screen and use a plastic opening tool to gently loosen the wire connection.
  6. Sony Vaio VGN-TXN25N Display Screen Replacement: paso 6, imagen 1 de 1
    • Remove the screen.
Conclusión
Una persona más ha completado esta guía.
Equipo
Cal Poly, Team 5-3, Forte Spring 2012 Miembro de Cal Poly, Team 5-3, Forte Spring 2012
CPSU-FORTE-S12S5G3
5 Miembros
12 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 3
Ultimos 30 días: 10
Todo El Tiempo: 3,587
