Saltar al contenido principal
Introducción
We are going to teach you how to remove and replace the battery.
  1. Flip the computer so that the bottom is facing up.
    • Flip the computer so that the bottom is facing up.
    • Look to the long edge where the computer screen is hinged and find the "release slide". It is located at the top left corner of the square indent.
  2. Kits de Reparación de Android
    Estás a un kit de tu nueva pantalla o batería.
    Comprar Ahora
    Comprar Ahora
  3. Use your finger to slide the release to the left.
    • Use your finger to slide the release to the left.
  4. While holding the release slide with one hand, use your opposite hand to pull the battery from its slot by gently shaking the battery left and right to help slide  it out. While holding the release slide with one hand, use your opposite hand to pull the battery from its slot by gently shaking the battery left and right to help slide  it out.
    • While holding the release slide with one hand, use your opposite hand to pull the battery from its slot by gently shaking the battery left and right to help slide it out.
Conclusión
Una persona más ha completado esta guía.
Austen
Miembro Desde 03/04/12
32 Reputación
2 Guías creadas
Equipo
Cal Poly, Team 5-3, Forte Spring 2012 Miembro de Cal Poly, Team 5-3, Forte Spring 2012
CPSU-FORTE-S12S5G3
5 Miembros
6 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 7
Todo El Tiempo: 1,572
