Introducción
Common reasons for optical drive replacement: constant reading errors, the drive does not spin, or has become too noisy.
In this guide, you will learn how to replace the optical drive for your device. Please remember to unplug the charging cable, since it could result in electric shock.
Qué necesitas
Remove one 5 mm Phillips #1 pan head screw, in the middle of the laptop, using a Bit Driver with Phillips PH1 bit.
Remove seven 5 mm Phillips #1 pan head screws with a Bit Driver, using a Phillips PH1 bit.
