Saltar al contenido principal
Fix Your Stuff
Right to Repair
Parts & Tools
Introducción
This guide is very easy to complete, because back in the day computers were easier to take apart! Hope you enjoy. The only thing is that I cannot find replacement RAM, so if you can find replacement RAM for this particular machine I will include you in the honorable mentions. A picture of the RAM with the label is on step 1 on the second photo.
Partes
No se especificaron partes.
  1. Flip the computer over, and remove all screws circled in picture provided. Set these screws aside for later in a place they will not be lost.
    • Flip the computer over, and remove all screws circled in picture provided.
    • Set these screws aside for later in a place they will not be lost.
    • Flip the computer over and open the lid. Then take the trackpad/wrist-rest off the computer slightly but not too fast because there is a ribbon cable to disconnect. Once you have disconnected the ribbon cable set aside the assembly
    • Be careful! There is a delicate ribbon cable to detach before fully removing the assembly. Damaging/ripping this cable will render your trackpad useless.
    • Push the two white pieces holding the RAM aside and then push the RAM up.
    • Remove the RAM from the computer and set it aside.
    • Insert your replacement RAM into the slot, then push down gently until the plastic holders click and hold the RAM into place.
    • If the RAM does not go down fairly easily when you put it in, adjust it, don’t keep pushing because that’s an easy way to break your RAM.
    • Re-connect the ribbon cable from the trackpad/wrist-rest, then place the assembly down onto it’s mount and close the computer lid, and then flip it back over.
Conclusión
To reassemble your device, follow step 1 in reverse order.
Una persona más ha completado esta guía.
Aaron Cooke
Miembro Desde 28/08/18
19,661 Reputación
21 Guías creadas
Equipo
NIWOTech Miembro de NIWOTech
Community
0 Miembros
0 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 5
Todo El Tiempo: 80
