Saltar al contenido principal
Sony Vaio PCG-4121GL Wifi Board Replacement
Qué necesitas
  1. Sony Vaio PCG-4121GL Wifi Board Replacement, Battery: paso 1, imagen 1 de 2 Sony Vaio PCG-4121GL Wifi Board Replacement, Battery: paso 1, imagen 2 de 2
    • Remove the two 3mm Phillips #0 screws on the bottom of the computer that secure the plastic backing.
  2. Sony Vaio PCG-4121GL Wifi Board Replacement: paso 2, imagen 1 de 3 Sony Vaio PCG-4121GL Wifi Board Replacement: paso 2, imagen 2 de 3 Sony Vaio PCG-4121GL Wifi Board Replacement: paso 2, imagen 3 de 3
    • Pull the bottom plate towards yourself until it unhinges fully.
    • Once the plate is free from the backing remove it completely.
  3. Sony Vaio PCG-4121GL Wifi Board Replacement: paso 3, imagen 1 de 1
    • Look for the blue tab that is located to the bottom left of the battery.
  4. Sony Vaio PCG-4121GL Wifi Board Replacement: paso 4, imagen 1 de 3 Sony Vaio PCG-4121GL Wifi Board Replacement: paso 4, imagen 2 de 3 Sony Vaio PCG-4121GL Wifi Board Replacement: paso 4, imagen 3 de 3
    • Pull the blue tab towards yourself until you hear a click.
    • Once the blue tab is released, pull up on the battery.
    • Once the battery can move freely, take it out completely.
    • It may be helpful to have a spudger to make it easier to release the blue tab.
  5. Sony Vaio PCG-4121GL Wifi Board Replacement, WiFi Board: paso 5, imagen 1 de 2 Sony Vaio PCG-4121GL Wifi Board Replacement, WiFi Board: paso 5, imagen 2 de 2
    • Lift up the two golden knobs on the left side of the WiFi board.
    • Remove the single 3mm Phillips #0 screw located on the WiFi board to the top left of the battery compartment.
  6. Sony Vaio PCG-4121GL Wifi Board Replacement: paso 6, imagen 1 de 2 Sony Vaio PCG-4121GL Wifi Board Replacement: paso 6, imagen 2 de 2
    • Once the screw and the golden knobs have been disconnected, pull the WiFi board out to the left.
    • Once the WiFi board is free from the device, remove completely.
Conclusión
Miguel Camarena
Miembro Desde 01/24/19
367 Reputación
3 Guías creadas
Equipo
Cal Poly, Team S2-G2, White Winter 2019 Miembro de Cal Poly, Team S2-G2, White Winter 2019
CPSU-WHITE-W19S2G2
4 Miembros
10 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 3
Ultimos 30 días: 15
Todo El Tiempo: 623
