Saltar al contenido principal
Sony Vaio PCG-4121GL Battery Replacement
Qué necesitas
  1. Sony Vaio PCG-4121GL Battery Replacement, Battery: paso 1, imagen 1 de 2 Sony Vaio PCG-4121GL Battery Replacement, Battery: paso 1, imagen 2 de 2
    • Remove the two 3mm Phillips #0 screws on the bottom of the computer that secure the plastic backing.
  2. Sony Vaio PCG-4121GL Battery Replacement: paso 2, imagen 1 de 3 Sony Vaio PCG-4121GL Battery Replacement: paso 2, imagen 2 de 3 Sony Vaio PCG-4121GL Battery Replacement: paso 2, imagen 3 de 3
    • Pull the bottom plate towards yourself until it unhinges fully.
    • Once the plate is free from the backing remove it completely.
  3. Sony Vaio PCG-4121GL Battery Replacement: paso 3, imagen 1 de 1
    • Look for the blue tab that is located to the bottom left of the battery.
  4. Sony Vaio PCG-4121GL Battery Replacement: paso 4, imagen 1 de 3 Sony Vaio PCG-4121GL Battery Replacement: paso 4, imagen 2 de 3 Sony Vaio PCG-4121GL Battery Replacement: paso 4, imagen 3 de 3
    • Pull the blue tab towards yourself until you hear a click.
    • Once the blue tab is released, pull up on the battery.
    • Once the battery can move freely, take it out completely.
    • It may be helpful to have a spudger to make it easier to release the blue tab.
Conclusión
Una persona más ha completado esta guía.
Equipo
Cal Poly, Team S2-G2, White Winter 2019 Miembro de Cal Poly, Team S2-G2, White Winter 2019
CPSU-WHITE-W19S2G2
4 Miembros
10 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 9
Ultimos 30 días: 41
Todo El Tiempo: 2,683
