Saltar al contenido principal
Sony Vaio PCG-31311L Motherboard Replacement
Qué necesitas
  1. Sony Vaio PCG-31311L Motherboard Replacement, Keyboard: paso 1, imagen 1 de 2 Sony Vaio PCG-31311L Motherboard Replacement, Keyboard: paso 1, imagen 2 de 2
    • Start with device closed, powered off, and upside down.
    • Locate 3 screws on the bottom plate and unscrew
    • These screws do not detach from the bottom plate.
  2. Sony Vaio PCG-31311L Motherboard Replacement: paso 2, imagen 1 de 2 Sony Vaio PCG-31311L Motherboard Replacement: paso 2, imagen 2 de 2
    • Use a plastic opening tool to pry up on the plate and remove from device.
  3. Sony Vaio PCG-31311L Motherboard Replacement: paso 3, imagen 1 de 1
    • Locate screw labeled "KB" and remove.
  4. Sony Vaio PCG-31311L Motherboard Replacement: paso 4, imagen 1 de 3 Sony Vaio PCG-31311L Motherboard Replacement: paso 4, imagen 2 de 3 Sony Vaio PCG-31311L Motherboard Replacement: paso 4, imagen 3 de 3
    • Use a plastic opening tool tool to pry around the edge of the keyboard.
  5. Sony Vaio PCG-31311L Motherboard Replacement: paso 5, imagen 1 de 3 Sony Vaio PCG-31311L Motherboard Replacement: paso 5, imagen 2 de 3 Sony Vaio PCG-31311L Motherboard Replacement: paso 5, imagen 3 de 3
    • Once detached, tilt the keyboard forward, exposing a blue ribbon cable.
    • Place finger on black tab and pull back. Then, give a gentle tug on the ribbon cable and it will detach.
    • Once the ribbon cable has been detached, lift the keyboard away from the device.
  6. Sony Vaio PCG-31311L Motherboard Replacement, Motherboard: paso 6, imagen 1 de 2 Sony Vaio PCG-31311L Motherboard Replacement, Motherboard: paso 6, imagen 2 de 2
    • Use the plastic opening tool to pull back the ribbon cables attached to the motherboard
    • Use the plastic opening tool to pop up the black tabs and pull the remaining ribbon cables.
  7. Sony Vaio PCG-31311L Motherboard Replacement: paso 7, imagen 1 de 2 Sony Vaio PCG-31311L Motherboard Replacement: paso 7, imagen 2 de 2
    • Locate the LCD ribbon cable
    • Pull up and away from device to detach the LCD ribbon cable.
  8. Sony Vaio PCG-31311L Motherboard Replacement: paso 8, imagen 1 de 3 Sony Vaio PCG-31311L Motherboard Replacement: paso 8, imagen 2 de 3 Sony Vaio PCG-31311L Motherboard Replacement: paso 8, imagen 3 de 3
    • Close and flip over laptop.
    • Locate the WiFi network card.
    • Use the plastic opening tool to pry up the two connectors.
  9. Sony Vaio PCG-31311L Motherboard Replacement: paso 9, imagen 1 de 2 Sony Vaio PCG-31311L Motherboard Replacement: paso 9, imagen 2 de 2
    • Locate the 6 screws on the bottom and remove.
    • Remove the final screw in the center to release the motherboard from the case.
Conclusión
Una persona más ha completado esta guía.
Tyler
Miembro Desde 08/24/16
45 Reputación
5 Guías creadas
Equipo
USF Tampa, Team 1-1, Lacy Fall 2016 Miembro de USF Tampa, Team 1-1, Lacy Fall 2016
USFT-LACY-F16S1G1
5 Miembros
10 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 1
Ultimos 30 días: 10
Todo El Tiempo: 1,546
