Introducción
Are your speakers in your Sony Vaio PCG-161L no longer working? You can replace them in 30 minutes using this guide.
Qué necesitas
Turn your device upside down and remove the 6 10mm screws attaching the back casing to the device using a phillips head screwdriver.
Remove the three 10 mm screws holding the casing to the top of the motherboard using a Phillips screwdriver.
Una persona más ha completado esta guía.
