Saltar al contenido principal
Sony Vaio PCG-161L Keyboard Replacement
Qué necesitas
  1. Sony Vaio PCG-161L Keyboard Replacement, Keyboard: paso 1, imagen 1 de 1
    • Turn your device upside down and remove the 6 10mm screws attaching the back casing to the device using a phillips head screwdriver.
  2. Sony Vaio PCG-161L Keyboard Replacement: paso 2, imagen 1 de 2 Sony Vaio PCG-161L Keyboard Replacement: paso 2, imagen 2 de 2
    • Lift up underneath the keyboard using the iFixit opening tool to expose the ribbon wires connecting the keyboard to the motherboard.
  3. Sony Vaio PCG-161L Keyboard Replacement: paso 3, imagen 1 de 2 Sony Vaio PCG-161L Keyboard Replacement: paso 3, imagen 2 de 2
    • The two ribbon cables connecting the keyboard to the motherboard are held in using zero insertion force (ZIF) connectors.
    • Use a plastic opening tool or your fingernail to flip up the small retaining flaps, then pull the ribbon cables out of their connectors.
Conclusión
Roman Alshehri
Miembro Desde 03/08/17
407 Reputación
4 Guías creadas
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 3
Ultimos 30 días: 5
Todo El Tiempo: 311
