Saltar al contenido principal
Sony Vaio Fit SVF15N26CXB Speaker Replacement
Qué necesitas
  1. Sony Vaio Fit SVF15N26CXB Speaker Replacement, Battery: paso 1, imagen 1 de 2 Sony Vaio Fit SVF15N26CXB Speaker Replacement, Battery: paso 1, imagen 2 de 2
    • Remove the following ten screws from the bottom case of the laptop:
    • Two 6.5mm Phillips #00 Phillips screws.
    • Four 8.95mm Phillips #00 screws.
    • Four 6.25mm Phillips #00 screws.
    • The screws may be hidden underneath a rubber foot that can be removed with a spudger.
  2. Sony Vaio Fit SVF15N26CXB Speaker Replacement: paso 2, imagen 1 de 2 Sony Vaio Fit SVF15N26CXB Speaker Replacement: paso 2, imagen 2 de 2
    • Use a plastic opening tool to separate the bottom cover from the laptop.
    • Lift the lower cover and pull away from the laptop.
  3. Sony Vaio Fit SVF15N26CXB Speaker Replacement: paso 3, imagen 1 de 3 Sony Vaio Fit SVF15N26CXB Speaker Replacement: paso 3, imagen 2 de 3 Sony Vaio Fit SVF15N26CXB Speaker Replacement: paso 3, imagen 3 de 3
    • Remove the eight Phillips #00 screws from the battery:
    • Six 4.65mm screws.
    • Two 4.65mm screws.
  4. Sony Vaio Fit SVF15N26CXB Speaker Replacement: paso 4, imagen 1 de 1
    • Lift the battery up and pull it out of the laptop.
  5. Sony Vaio Fit SVF15N26CXB Speaker Replacement, Speaker: paso 5, imagen 1 de 3 Sony Vaio Fit SVF15N26CXB Speaker Replacement, Speaker: paso 5, imagen 2 de 3 Sony Vaio Fit SVF15N26CXB Speaker Replacement, Speaker: paso 5, imagen 3 de 3
    • Remove six 5.75mm Phillips #00 screws from the speakers.
  6. Sony Vaio Fit SVF15N26CXB Speaker Replacement: paso 6, imagen 1 de 3 Sony Vaio Fit SVF15N26CXB Speaker Replacement: paso 6, imagen 2 de 3 Sony Vaio Fit SVF15N26CXB Speaker Replacement: paso 6, imagen 3 de 3
    • Use a spudger to flip up the black latch on the four ZIF connectors.
    • Remove the four ribbon cables from the ZIF connectors.
    • Disconnect the speaker from the board.
  7. Sony Vaio Fit SVF15N26CXB Speaker Replacement: paso 7, imagen 1 de 2 Sony Vaio Fit SVF15N26CXB Speaker Replacement: paso 7, imagen 2 de 2
    Herramienta utilizada en este paso:
    Comprar
    • Using tweezers, carefully unwind the speakers' wires from the plastic brackets holding them.
    • Where the wire is stuck under tape, gently pull the tape up until the wire is free.
    • Do not remove the tape.
  8. Sony Vaio Fit SVF15N26CXB Speaker Replacement: paso 8, imagen 1 de 1
    • Remove the speakers by picking the left and right pieces up and lifting them up and out of the computer.
Conclusión
Una persona más ha completado esta guía.
Althea McDavid
Miembro Desde 02/14/18
857 Reputación
6 Guías creadas
Equipo
USF Tampa, Team S2-G4, Nance Spring 2018 Miembro de USF Tampa, Team S2-G4, Nance Spring 2018
USFT-NANCE-S18S2G4
4 Miembros
12 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 5
Ultimos 30 días: 15
Todo El Tiempo: 497
