Saltar al contenido principal
Sony Vaio Fit SVF15N26CXB Hard Drive Replacement
Qué necesitas
  1. Sony Vaio Fit SVF15N26CXB Hard Drive Replacement, Battery: paso 1, imagen 1 de 2 Sony Vaio Fit SVF15N26CXB Hard Drive Replacement, Battery: paso 1, imagen 2 de 2
    • Remove the following ten screws from the bottom case of the laptop:
    • Two 6.5mm Phillips #00 Phillips screws.
    • Four 8.95mm Phillips #00 screws.
    • Four 6.25mm Phillips #00 screws.
    • The screws may be hidden underneath a rubber foot that can be removed with a spudger.
  2. Sony Vaio Fit SVF15N26CXB Hard Drive Replacement: paso 2, imagen 1 de 2 Sony Vaio Fit SVF15N26CXB Hard Drive Replacement: paso 2, imagen 2 de 2
    • Use a plastic opening tool to separate the bottom cover from the laptop.
    • Lift the lower cover and pull away from the laptop.
  3. Sony Vaio Fit SVF15N26CXB Hard Drive Replacement: paso 3, imagen 1 de 3 Sony Vaio Fit SVF15N26CXB Hard Drive Replacement: paso 3, imagen 2 de 3 Sony Vaio Fit SVF15N26CXB Hard Drive Replacement: paso 3, imagen 3 de 3
    • Remove the eight Phillips #00 screws from the battery:
    • Six 4.65mm screws.
    • Two 4.65mm screws.
  4. Sony Vaio Fit SVF15N26CXB Hard Drive Replacement: paso 4, imagen 1 de 1
    • Lift the battery up and pull it out of the laptop.
  5. Sony Vaio Fit SVF15N26CXB Hard Drive Replacement, Hard Drive: paso 5, imagen 1 de 2 Sony Vaio Fit SVF15N26CXB Hard Drive Replacement, Hard Drive: paso 5, imagen 2 de 2
    • Remove the four 3.20mm Phillips #00 screws from the hard drive.
  6. Sony Vaio Fit SVF15N26CXB Hard Drive Replacement: paso 6, imagen 1 de 3 Sony Vaio Fit SVF15N26CXB Hard Drive Replacement: paso 6, imagen 2 de 3 Sony Vaio Fit SVF15N26CXB Hard Drive Replacement: paso 6, imagen 3 de 3
    • Use a spudger to flip up the black latch on the ZIF connectors.
    • Pull the ribbon cables out of the ZIF connectors and fold them over the hard drive.
    • Disconnect the hard drive and remove.
  7. Sony Vaio Fit SVF15N26CXB Hard Drive Replacement: paso 7, imagen 1 de 2 Sony Vaio Fit SVF15N26CXB Hard Drive Replacement: paso 7, imagen 2 de 2
    • Remove the four 3.70mm Phillips #00 screws from the hard drive mounting case.
    • Carefully peel foil tray off of hard drive.
Conclusión
2 personas más completaron esta guía.
Althea McDavid
Miembro Desde 02/14/18
857 Reputación
6 Guías creadas
Equipo
USF Tampa, Team S2-G4, Nance Spring 2018 Miembro de USF Tampa, Team S2-G4, Nance Spring 2018
USFT-NANCE-S18S2G4
4 Miembros
12 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 3
Ultimos 30 días: 17
Todo El Tiempo: 1,164
