Saltar al contenido principal
Sony Vaio Fit SVF14A190X Hard Drive Replacement
Qué necesitas
  1. Sony Vaio Fit SVF14A190X Hard Drive Replacement, Battery Replacement: paso 1, imagen 1 de 1
    • Make sure the battery is drained or the computer is turned off.
    • Use the Phillips head screw driver to remove the eleven 6 mm screws.
    • Use the Phillips head screw driver to remove the one 4 mm screw securing the CD drive.
  2. Sony Vaio Fit SVF14A190X Hard Drive Replacement: paso 2, imagen 1 de 3 Sony Vaio Fit SVF14A190X Hard Drive Replacement: paso 2, imagen 2 de 3 Sony Vaio Fit SVF14A190X Hard Drive Replacement: paso 2, imagen 3 de 3
    • Insert the plastic opening tool into the slit of the CD drive.
    • Then pull it outwards.
    • Grab the CD drive with your hand.
    • Take the CD drive all the way out.
  3. Sony Vaio Fit SVF14A190X Hard Drive Replacement: paso 3, imagen 1 de 3 Sony Vaio Fit SVF14A190X Hard Drive Replacement: paso 3, imagen 2 de 3 Sony Vaio Fit SVF14A190X Hard Drive Replacement: paso 3, imagen 3 de 3
    • Insert the plastic opening tool into the slit between the back cover and the rest of the computer.
    • Move the plastic opening tool around all sides of the device.
    • Peel off the back cover.
  4. Sony Vaio Fit SVF14A190X Hard Drive Replacement: paso 4, imagen 1 de 2 Sony Vaio Fit SVF14A190X Hard Drive Replacement: paso 4, imagen 2 de 2
    • Use the Phillips head screw driver to remove the four 7 mm screws.
    • Lift the battery out with your hand.
  5. Sony Vaio Fit SVF14A190X Hard Drive Replacement, Hard Drive Replacement: paso 5, imagen 1 de 3 Sony Vaio Fit SVF14A190X Hard Drive Replacement, Hard Drive Replacement: paso 5, imagen 2 de 3 Sony Vaio Fit SVF14A190X Hard Drive Replacement, Hard Drive Replacement: paso 5, imagen 3 de 3
    • Use the Phillips head screw driver to remove four 4mm screws located on both sides of the hard drive.
  6. Sony Vaio Fit SVF14A190X Hard Drive Replacement: paso 6, imagen 1 de 2 Sony Vaio Fit SVF14A190X Hard Drive Replacement: paso 6, imagen 2 de 2
    • Use a plastic opening tool to lift the hard drive up to the point where it can be grabbed.
    • Pull the hard drive horizontally to separate it from it's connection.
Conclusión
Ryan Silberger
Miembro Desde 02/13/18
109 Reputación
1 Guía escrita
Equipo
USF Tampa, Team S11-G3, Cheng Spring 2018 Miembro de USF Tampa, Team S11-G3, Cheng Spring 2018
USFT-CHENG-S18S11G3
4 Miembros
11 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 5
Ultimos 30 días: 11
Todo El Tiempo: 820
