Introducción
This is an easy to follow, step by step guide to help aid in the replacement of the hard drive for the Sony Vaio Fit SVF14A190X. The hard drive is a component that store and retrieves information in the device.
Qué necesitas
Use the Phillips head screw driver to remove the eleven 6 mm screws.
Use the Phillips head screw driver to remove the one 4 mm screw securing the CD drive.
Use the Phillips head screw driver to remove four 4mm screws located on both sides of the hard drive.
