Saltar al contenido principal
Sony Vaio Fit 13A SVF13NA1EL Screen Connector
Qué necesitas
  1. Sony Vaio Fit 13A SVF13NA1EL Screen Connector, Sony Vaio Fit 13A SVF13NA1EL Screen Connector: paso 1, imagen 1 de 1
    • Flip over the screen
    • Remove all 8 screws as shown circled in the image using a Phillips #0
  2. Sony Vaio Fit 13A SVF13NA1EL Screen Connector: paso 2, imagen 1 de 3 Sony Vaio Fit 13A SVF13NA1EL Screen Connector: paso 2, imagen 2 de 3 Sony Vaio Fit 13A SVF13NA1EL Screen Connector: paso 2, imagen 3 de 3
    • Flip the screen back over.
    • Use a plastic spudger to remove the top section of the cover.
  3. Sony Vaio Fit 13A SVF13NA1EL Screen Connector: paso 3, imagen 1 de 1
    • Unplug the screen connecter from the back of the screen.
  4. Sony Vaio Fit 13A SVF13NA1EL Screen Connector: paso 4, imagen 1 de 1
    • Disconnect the ribbon wire from the LCD connector by gently pulling it.
  5. Sony Vaio Fit 13A SVF13NA1EL Screen Connector: paso 5, imagen 1 de 2 Sony Vaio Fit 13A SVF13NA1EL Screen Connector: paso 5, imagen 2 de 2
    • Gently raise the metal framework of the laptop to reveal the remaining portion of the screen connector.
    • Follow the ribbon wiring to where it connects to the screen.
    • Carefully pull the wiring to disconnect and click it back in place to reconnect.
Conclusión
4 personas más completaron esta guía.
5 comentarios
Where to buy or to repair screen connector for Vaio Fit SVF13N13
Adham Ahmed - Contestar
Where to replace the keyboard of Vaio SVF13N2
Arturo Dameno - Contestar
The procedure is nicely explained
Is there an option to replace the LCD flet cable ... ?
It is complicated but we found a defect on the flet cable.
servis računara - Contestar
I found some spareparts over the sony website. With all data from you laptop you can find them here https://uk.eetgroup.com/Guide/m/Sony-VAI...
Lukas Lutz - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 9
Ultimos 7 días: 20
Ultimos 30 días: 40
Todo El Tiempo: 4,234
