Saltar al contenido principal
Sony Vaio Fit 13A SVF13NA1EL Battery Replacement
Qué necesitas
  1. Sony Vaio Fit 13A SVF13NA1EL Battery Replacement, Battery: paso 1, imagen 1 de 1
    • Begin by turning the laptop top-down on a flat surface.
    • Use a JIS #1 screwdriver to remove the 4 screws circled in red
    • Use a JIS #0 screwdriver to remove the 8 screws circled in orange
    • Many of these screws are located underneath the rubber pads on the device.
    • Keep track of the locations of the screws removed for ease of reassembly.
  2. Sony Vaio Fit 13A SVF13NA1EL Battery Replacement: paso 2, imagen 1 de 1
    • Use a spudger to carefully remove the back cover of the laptop.
    • Be careful when lifting around the ports and headphone jack to avoid causing damage to these components.
  3. Sony Vaio Fit 13A SVF13NA1EL Battery Replacement: paso 3, imagen 1 de 2 Sony Vaio Fit 13A SVF13NA1EL Battery Replacement: paso 3, imagen 2 de 2
    • Lift up back cover to access internal components of the laptop.
  4. Sony Vaio Fit 13A SVF13NA1EL Battery Replacement: paso 4, imagen 1 de 1
    • Remove the screws in the circled areas using the J0 Screwdriver to release the battery.
  5. Sony Vaio Fit 13A SVF13NA1EL Battery Replacement: paso 5, imagen 1 de 2 Sony Vaio Fit 13A SVF13NA1EL Battery Replacement: paso 5, imagen 2 de 2
    • Lift the battery from the laptop to remove.
    • Replace if necessary.
Conclusión
2 personas más completaron esta guía.
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 4
Ultimos 7 días: 11
Ultimos 30 días: 62
Todo El Tiempo: 3,928
