Saltar al contenido principal
Sony Vaio Fit 13A Heatsink + Fan Assembly Replacement
Qué necesitas
  1. Sony Vaio Fit 13A Heatsink + Fan Assembly Replacement, Back Cover: paso 1, imagen 1 de 2 Sony Vaio Fit 13A Heatsink + Fan Assembly Replacement, Back Cover: paso 1, imagen 2 de 2
    • Starting with the laptop top-down, locate and remove the twelve 1mm Phillips #0 screws securing the back cover to the main body of the computer.
  2. Sony Vaio Fit 13A Heatsink + Fan Assembly Replacement: paso 2, imagen 1 de 2 Sony Vaio Fit 13A Heatsink + Fan Assembly Replacement: paso 2, imagen 2 de 2
    • Use the Plastic Opening Tools or Metal Spudger to carefully loosen back cover from the body of the computer.
    • Be sure to avoid headphone jack when removing back cover by lifting cover away from computer and up.
  3. Sony Vaio Fit 13A Heatsink + Fan Assembly Replacement: paso 3, imagen 1 de 1
    • Lift off back cover to access inner components of computer.
  4. Sony Vaio Fit 13A Heatsink + Fan Assembly Replacement, Fan: paso 4, imagen 1 de 2 Sony Vaio Fit 13A Heatsink + Fan Assembly Replacement, Fan: paso 4, imagen 2 de 2
    • Remove the three 1mm Phillips #0 screws surrounding the fan.
    • Loosen the three 1mm Phillips #0 screws. These screws will stay captive to the heatsink.
  5. Sony Vaio Fit 13A Heatsink + Fan Assembly Replacement: paso 5, imagen 1 de 3 Sony Vaio Fit 13A Heatsink + Fan Assembly Replacement: paso 5, imagen 2 de 3 Sony Vaio Fit 13A Heatsink + Fan Assembly Replacement: paso 5, imagen 3 de 3
    Herramienta utilizada en este paso:
    Comprar
    • Use tweezers to carefully unplug the fan connector.
  6. Sony Vaio Fit 13A Heatsink + Fan Assembly Replacement, Remove the Fan: paso 6, imagen 1 de 2 Sony Vaio Fit 13A Heatsink + Fan Assembly Replacement, Remove the Fan: paso 6, imagen 2 de 2
    • Use the Plastic Opening Tool to gently remove the heat sink and fan assembly from the computer.
    • Important: Follow the How to Apply Thermal Paste guide to replace the thermal paste before reassembling your device.
Conclusión
4 personas más completaron esta guía.
Marii
Miembro Desde 01/08/15
658 Reputación
3 Guías creadas
Equipo
Cal Poly, Team 21-19, Maness Winter 2015 Miembro de Cal Poly, Team 21-19, Maness Winter 2015
CPSU-MANESS-W15S21G19
4 Miembros
12 Guías creadas
Un comentario
Could you also maybe do a tutorial on Sony Vaio Fit 13? http://www.laptoppartstore.com/replace--... Any luck figuring out how the fan may be detached and re-attached to the heatsink? Also, I notice a very specific type of taping... where can one procure those?
Abhishek D - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 9
Todo El Tiempo: 4,570
