Saltar al contenido principal
Sony Vaio Fit 13A Battery Replacement
Qué necesitas
  1. Sony Vaio Fit 13A Battery Replacement, Back Cover: paso 1, imagen 1 de 2 Sony Vaio Fit 13A Battery Replacement, Back Cover: paso 1, imagen 2 de 2
    • Starting with the laptop top-down, locate and remove the twelve 1mm Phillips #0 screws securing the back cover to the main body of the computer.
  2. Sony Vaio Fit 13A Battery Replacement: paso 2, imagen 1 de 2 Sony Vaio Fit 13A Battery Replacement: paso 2, imagen 2 de 2
    • Use the Plastic Opening Tools or Metal Spudger to carefully loosen back cover from the body of the computer.
    • Be sure to avoid headphone jack when removing back cover by lifting cover away from computer and up.
  3. Sony Vaio Fit 13A Battery Replacement: paso 3, imagen 1 de 1
    • Lift off back cover to access inner components of computer.
  4. Sony Vaio Fit 13A Battery Replacement, Battery: paso 4, imagen 1 de 2 Sony Vaio Fit 13A Battery Replacement, Battery: paso 4, imagen 2 de 2
    • Locate and remove the ten 1mm Phillips #0 screws that are securing the battery in place.
  5. Sony Vaio Fit 13A Battery Replacement: paso 5, imagen 1 de 2 Sony Vaio Fit 13A Battery Replacement: paso 5, imagen 2 de 2
    • Remove the battery with the Plastic Opening Tool by placing the tool between the battery and the computer and cautiously prying it out.
Conclusión
3 personas más completaron esta guía.
Alex Prange
Miembro Desde 01/08/15
527 Reputación
3 Guías creadas
Equipo
Cal Poly, Team 21-19, Maness Winter 2015 Miembro de Cal Poly, Team 21-19, Maness Winter 2015
CPSU-MANESS-W15S21G19
4 Miembros
12 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 5
Ultimos 30 días: 19
Todo El Tiempo: 7,779
