Saltar al contenido principal
Introducción
This will guide you in replacing the Media Board of a Sony Vaio VPCF 132FX
Herramientas
No se especificaron herramientas.
Partes
No se especificaron partes.
  1. Remove all wires then flip the laptop
    • Remove all wires then flip the laptop
  2. Remove the battery Remove the battery
    • Remove the battery
  3. Kits de Reparación de Batería de MacBook Air
    A partir de $69.99
    Buy Now
    A partir de $69.99
    Buy Now
  4. Remove the screws and flip it back.
    • Remove the screws and flip it back.
  5. Lift the screen and slide your nail or any flat plastic to the side of the cover to unclip it. Slide from the sides towards the center. Slide from the sides towards the center.
    • Lift the screen and slide your nail or any flat plastic to the side of the cover to unclip it.
    • Slide from the sides towards the center.
  6. Gently remove the wire of the Power Button.
    • Gently remove the wire of the Power Button.
  7. Unlock the Lock. Unscrew the 3 Flat screws and remove the Media Board. You may skip this step if replacing the Power Button.
    • Unlock the Lock.
    • Unscrew the 3 Flat screws and remove the Media Board.
    • You may skip this step if replacing the Power Button.
Conclusión
Una persona más ha completado esta guía.
trickster
Miembro Desde 23/12/13
1,941 Reputación
11 Guías creadas
What are the functions of the media board? My vaio vgn-fw170j won't power up (no LEDS on the power switch, or anywhere else, no fan, nothing). Verified that MoBo has 19.5 VDC on the board. Replaced MoBo and CPU, still no response. Since power button plugs into Media Board, figured it might be failed - any idea if this could be the cause?
course2kid - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 1
Últimos 30 Días: 5
Todo El Tiempo: 1,130
