Saltar al contenido principal
Sony VAIO VPCEE26FX RAM Replacement
Qué necesitas
  1. Sony VAIO VPCEE26FX RAM Replacement, Battery: paso 1, imagen 1 de 2 Sony VAIO VPCEE26FX RAM Replacement, Battery: paso 1, imagen 2 de 2
    • Ensure that the laptop is powered off before disconnecting the battery.
    • Flip the laptop over so the underside of the laptop is facing up.
  2. Sony VAIO VPCEE26FX RAM Replacement: paso 2, imagen 1 de 2 Sony VAIO VPCEE26FX RAM Replacement: paso 2, imagen 2 de 2
    • Slide the two tabs towards each other until the battery disconnects slightly from its position.
    • Carefully lift the battery out of its position away from the laptop.
    • The battery is not pictured here, since it is missing from this particular device.
  3. Sony VAIO VPCEE26FX RAM Replacement, RAM: paso 3, imagen 1 de 1
    • Using a JIS #0 screwdriver, loosen the captive screw attached to the RAM cover.
    • This screw will not come out all the way, but will remain attached to the cover instead.
  4. Sony VAIO VPCEE26FX RAM Replacement: paso 4, imagen 1 de 1
    • Remove the cover which will reveal the two RAM sticks.
  5. Sony VAIO VPCEE26FX RAM Replacement: paso 5, imagen 1 de 3 Sony VAIO VPCEE26FX RAM Replacement: paso 5, imagen 2 de 3 Sony VAIO VPCEE26FX RAM Replacement: paso 5, imagen 3 de 3
    • Push the two tabs holding the RAM sticks in place, away from each other.
    • The first RAM stick will pop up out of place. Remove it away from its position.
  6. Sony VAIO VPCEE26FX RAM Replacement: paso 6, imagen 1 de 3 Sony VAIO VPCEE26FX RAM Replacement: paso 6, imagen 2 de 3 Sony VAIO VPCEE26FX RAM Replacement: paso 6, imagen 3 de 3
    • Push the two tabs holding the second RAM stick in, away from each other.
    • The second RAM stick will pop up out of place. Remove it away from its position.
Conclusión
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 5
Ultimos 30 días: 17
Todo El Tiempo: 1,382
