Saltar al contenido principal
Sony VAIO VPCEE26FX Optical Drive Replacement
Qué necesitas
  1. Sony VAIO VPCEE26FX Optical Drive Replacement, Battery: paso 1, imagen 1 de 2 Sony VAIO VPCEE26FX Optical Drive Replacement, Battery: paso 1, imagen 2 de 2
    • Ensure that the laptop is powered off before disconnecting the battery.
    • Flip the laptop over so the underside of the laptop is facing up.
  2. Sony VAIO VPCEE26FX Optical Drive Replacement: paso 2, imagen 1 de 2 Sony VAIO VPCEE26FX Optical Drive Replacement: paso 2, imagen 2 de 2
    • Slide the two tabs towards each other until the battery disconnects slightly from its position.
    • Carefully lift the battery out of its position away from the laptop.
    • The battery is not pictured here, since it is missing from this particular device.
  3. Sony VAIO VPCEE26FX Optical Drive Replacement, Optical Drive: paso 3, imagen 1 de 1
    • Use a JIS #0 screwdriver to remove the 4mm screw from its place.
  4. Sony VAIO VPCEE26FX Optical Drive Replacement: paso 4, imagen 1 de 2 Sony VAIO VPCEE26FX Optical Drive Replacement: paso 4, imagen 2 de 2
    • Remove the optical drive gently away from its holder on the laptop.
Conclusión
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 8
Ultimos 30 días: 14
Todo El Tiempo: 446
